Heater Only Blowing Hot Air
21 replies to this topic
#1 studavis
studavis
  • 65 posts
Posted 12 July 2011 - 08:21 PM
Model: Mayfair
Year: B plate 1984
Ok, in short my heater only seems to be blowing hot air into the car.
Here's the situation - when the heater is switched to ON and the heater push / pull is fully depressed.....
Switched to 'Car': really hot air is blown out of the heater block (below centre). Neither dash air blowers are working
Switched to 'Screen': really hot air blows out below the heater (as above), nothing blows out of the vents at the top of the dash onto windscreen
Switched to 'Off': No air is blown out of below (but block remains hot) and nothing blown out of dash heaters (as above)
So, it only ever seems to blow hot in any of the combinations above - both pipes are connected to the central heater block as expected, but obviously something isn't right.
Any ideas? Thanks! :D
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 12 July 2011 - 08:23 PM
Sounds like the hot/cold valve on the head is stuck open, try moving it by hand or take it off and free it up.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 July 2011 - 08:32 PM
A 'heater' by definition is designed to blow hot air - sounds like it's working well......
#4 studavis
studavis
  • 65 posts
Posted 12 July 2011 - 08:35 PM
Bit of a noob on this - can you explain where I can find this? Sorry and thanks :D
#5 Pete93
Pete93
  • 189 posts
Posted 12 July 2011 - 08:38 PM
It's a valve on the top left of the head next to the rocker cover with a pipe sticking out of it.
#6 danrock101
danrock101
  • 2,478 posts
Posted 12 July 2011 - 08:39 PM
generally HEATERS only blow hot air :D
the heater tap the matrix is the thing with the pipe and *bike break cable looking thing* coming off it, either of the left of the top of the engine or the top right of the engine bay on one of the 2 pipes
Edited by danrock101, 12 July 2011 - 08:41 PM.
#7 studavis
studavis
  • 65 posts
Posted 12 July 2011 - 08:49 PM
Would that solve the problem of the air not being distributed to the front screen vents?
#8 R1minimagic
R1minimagic
  • 4,660 posts
Posted 12 July 2011 - 08:56 PM
No, if you pull one of the pipes off the side, is air coming out of that?
#9 Pete93
Pete93
  • 189 posts
Posted 12 July 2011 - 08:57 PM
No, there's a flap at the front of the heater matrix (inside it) which should open and close to do that.
#10 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 13 July 2011 - 10:53 AM
my heater only blows hot or scalding.
#11 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 13 July 2011 - 11:03 AM
[protip] Minis have a built in feature on each other the doors, if you wind the black handle, it'll put the window down >_<
#12 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 13 July 2011 - 11:32 AM
I always wondered what that knob was for, didnt realise they could even blow cold air aha
#13 maggies_minder
maggies_minder
  • 4,393 posts
Posted 13 July 2011 - 09:39 PM
i dont think they can, its a heater not a fan... >_<
#14 studavis
studavis
  • 65 posts
Posted 14 July 2011 - 01:31 PM
Ok folks, seem to have got it settled now, just one more question.....
My two dashboard air vents that blow out when turned clockwise, the driver side one is really strong as expected but the passenger side one is hardly blowing anything out - any notorious fail points for that to happen?
#15 maggies_minder
maggies_minder
  • 4,393 posts
Posted 14 July 2011 - 02:05 PM
the pipe from the front panel by the grille has more than likely fell off.
when the same pipe fell off on mine, i got really hot air coming through the passenger vent as it was the warm air from the rad.
