im so confusedi dont think they can, its a heater not a fan...I always wondered what that knob was for, didnt realise they could even blow cold air aha
Heater Only Blowing Hot Air
#16
Posted 14 July 2011 - 04:34 PM
#17
Posted 14 July 2011 - 05:03 PM
mine certainly doesnt with the knob pushed in, its hot. with it pulled out its boiling.im so confusedi dont think they can, its a heater not a fan...I always wondered what that knob was for, didnt realise they could even blow cold air aha
#18
Posted 14 July 2011 - 05:26 PM
if at any time the tap is opened, the water in there is hot and has no way to escape.
as many have said, its a heater so its meant to blow hot air.
the two air vents at either side of the dash are for cold air, (hence term fresh air vents). the left one has a smaller pick up on the front for the cold air to rush into, and a smaller pipe. therefore there is less of a 'ram effect' the drivers side one is quite large then goes to a smaller pipe (smaller than the pick up) which causes a lot of air to be pushed down the pipe. this is why the drivers one is stronger
#19
Posted 14 July 2011 - 09:01 PM
wow, thanks for the detailed explanation - very useful. The left one is barely trickling though, very very little coming out of it, which leads me to think there may be a problem - I presume that you should be feeling at least a decent 'blow' out of the left pipe?
#20
Posted 14 July 2011 - 09:24 PM
#21
Posted 14 July 2011 - 10:03 PM
the "blow" depends on how fast your going, the faster your travelling the faster the "blow" through the fresh air vents.the two air vents at either side of the dash are for cold air, (hence term fresh air vents). the left one has a smaller pick up on the front for the cold air to rush into, and a smaller pipe. therefore there is less of a 'ram effect' the drivers side one is quite large then goes to a smaller pipe (smaller than the pick up) which causes a lot of air to be pushed down the pipe. this is why the drivers one is stronger
youll find either your pipe has worked its way loose or its blocked.
either way a toddler could fix it.
#22
Posted 17 July 2011 - 12:07 PM
id take it off and poke something through it carefully to see if theres a blockage
