Thanks! So, I pulled the two wires off the switch and connected them together with the ignition turned to on position. The fan doesn't spin, but I hear a click. So the problem is the fan in itself. Other options than https://www.minispar...Back to search? Is it worthwhile? Daily driver. Thanks.
If you can hear a click, next you need to check this is translating into a supply at the fan using a multi meter, or, if you haven't got one a bulb will do.
