Sump Guards And Oil Coolers
18 replies to this topic
#16 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 17 July 2011 - 07:22 PM
It is a factor to consider, but for normal driving or even hard driving it wouldnt make any difference at all.
#17 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 18 July 2011 - 01:12 PM
Thats a very definite comment- "even hard driving it wouldnt make any difference at all"- do you want to be the reason someone might do some damage? Best to say "probably" or something similar in there as I'm pretty sure you can't be 100% sure, anyway what do you call hard driving? Racing and rallying are both hard driving IMO but they will be fine without an oil cooler??
#18 Cooperman
  • 23,326 posts
Posted 18 July 2011 - 02:37 PM
The old adage that "you can't advise those that won't be advised" comes to mind here.
You fit a sump guard for competition, hence you are going to be using a lot of revs and generating heat. The sump guard will seriously interfere with the airflow past the cooling fins on the sump. In fact, for serious rallying a piece of heavy density foam is often fitted between sump and guard to prevent mud & stones from lodging there.
Personally I would only ever fit a sump guard for rallying as it is expensive to fit a guard and an oil cooler and I would never have a sump guard without also having at least a 10-row cooler and preferably a 13-row. Also, a sump guard reduces the ground clearance so it's a good idea to raise the car up a bit, which is what you do on rally cars anyway.
But then, each to his own and if someone wants to take the risk of engine/gearbox damage due to overheated oil that's their business. I know I was surprised, when I first fitted a guard without a cooler to a 998 Cooper, at how quickly the oil pressure dropped when simply cruising up the M1 on a cool evening at 75 mph in top gear. The pressure halved in less than 20 miles of driving. The oil also has a major part to play in overall engine cooling, so if the oil heats up too much, so will the coolant water. Thus a 6-blade export fan might be a good idea if fitting a sump-guard.
#19 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 18 July 2011 - 05:18 PM
Hard driving i meant by on the road giving it some.
Blasting round silverstone for 15 laps where your flat out in every gear racing, yes you need a cooler and yes for rallying definitely.
Fit an oil temperature gague and take it from there.
