Hi all,
I'm really close to getting my Mini MOT'd after its restoration, theres one thing that will stop it from passing.
When i turn the headlights on theyre fine, however, when i switch the main beam on (using the stalk on the steering column) the left hand light goes to main beam, and the right hand light switches off completely. The situation is the same when i flash the headlights - only one comes on not both!
The bulbs are new so i dont think theyre the problem, what else can i check?
Cheers.
Main Beam Problem
RsSpyder
, Jul 24 2011 07:41 PM
1 reply to this topic
Posted 24 July 2011 - 07:41 PM
Posted 24 July 2011 - 08:33 PM
Check the bullit connectors behind the grill. disconnect,,,clean,,and push back together...they are rubbish and cause problemsHi all,
Cheers.
