I would like to arrange a group buy on the OBP manufactured pedal boxes for the mini.
These:
We can offer a hydraulic or cable clutch version plus different kits, prices vary.
Overview:
This pedal box has been designed specifically for the Classic Mini, we have worked very closely with a Mini specialist to create a hi-performance system that is easy to fit.
We are confident that our Mini bias brake pedal box is by far the best solution available on the market. This is a total replacement pedal box, not an add on part that does not work.
We have tested and designed the 6:1 pedal ratio to give optimum pedal performance. All our pedal boxes are manufactured in our UK based factory; this is how we can maintain the highest level of quality control.
The Mini pedal box is a light weight mild steel under-slung pedal box design, which offers the driver the highest level of efficiency in this critical area. The ergonomic design features a fabricated lightened steel brake and clutch pedal with oil impregnated spherical bushes that sets new standards in pedal box design. This pedal box is fitted with a bias bar that operates a dual master cylinder braking system, giving total control over the braking from front to rear.
Bulk Buy:
• 30% off RRP (3+people)
• 35% off RRP (6+people)
• 40% off RRP (15+people)
Prices vary depending on what model and kit you would like, please note down what part number you want and I will give you a price.
For more information on the pedal boxes and part numbers please visit this link:
http://www.obpltd.co...pedal-pedal-box
If you want to be involved in this group buy then please post your interest in this thread and I will add you to the list.
The group buy will end on 26th August, to give you time to save up or think about it.
Best Regards,
Sam.
1. paul190181
2.
3.
Edited by obp.ltd, 08 August 2011 - 10:23 AM.
