No Oil Pressure On New Build
Posted 06 August 2011 - 03:34 PM
Right first before the usual questions are asked:
- Yes the O-ring was fitted
- The pump was primed
- the oil relief valve is sealing oil from what I can tell
- I have a known working oil pressure gauge
Right other things.
There is oil coming through the hose to the oil pressure gauge, not in exactly a pressure form
There is oil coming through the transfer pipe to filter head, although not pressured is coming through in sort of spurts
When the oil filter is removed oil drains out of the centre part of the housing, so it seems that oil is making it out of the oil filter
The question is whats next?
I had it spinning pretty quickly (on a 14v tractor battery!!)
One thing I did notice is after cranking for a good 10 seconds, the pressure gauge needle moves off the stop to the 0 mark! so that tells me there is pressure of probably 1psi, so is this a bearing matter?
Posted 06 August 2011 - 03:52 PM
Posted 06 August 2011 - 04:03 PM
Just Cranked with plugs out and with a heavy duty battery or 2
Edited by liirge, 07 August 2011 - 11:23 AM.
Posted 06 August 2011 - 04:25 PM
Posted 06 August 2011 - 04:40 PM
if so it mayght be lieing due to the votage being pulled down by the starter.
generally if you use a capilery gauge or the std oil light as soon as you get a reading thats enough, even if its only a few lb.
Posted 06 August 2011 - 04:43 PM
Posted 06 August 2011 - 07:46 PM
My pressure relief valve was stuck partly open and I was only getting about 15 20psi.
I must have got dirt or something in the hole and it jammed the little piston.
Your ball bearing may have a flaw or something in the bottom of the hole.
Posted 06 August 2011 - 09:31 PM
Posted 07 August 2011 - 11:22 AM
I didn't actually double check the shells, they came from a supplier I've used many times and never had a problem, I hope its not a shell bearing supplied incorrectly!
No I'm using a capillary gauge, hence I said in my first post their is oil coming out of the tube going to the gauge
Even if it was partly open surely one would get more than a 0 reading on a gauge, and if it was open it wouldn't be spurting oil out of the transfer feed the filter head.
I will put another battery on charge and see if longer cranking time will help.
Posted 07 August 2011 - 02:28 PM
Posted 07 August 2011 - 04:53 PM
If it was partly open the oil pressure would not build up properly
You would just get the oil that the pump could deliver without any pressure to it.
The relief valve lets the pressure build up then releases it , opening and shutting all the time so if it aint closed properly then you will just get a trickle.
try taking the valve out and turning the engine backwards pumping oil into the relief valve hole with an oil can as you do it, that'll fill the pump good and proper just in case it's not primed properly.
Posted 07 August 2011 - 08:16 PM
Yup i pre-filled the oil filter.
I'll see if I can find the bullet and try that.
Posted 07 August 2011 - 09:45 PM
Posted 07 August 2011 - 09:48 PM
and yes plugs are out! spins over nice and quickly, starter motor got pretty hot though.
Posted 07 August 2011 - 09:49 PM
Dont want to worry you but the oil pick up pipe is ok and not partially blocked is it..It is primed 100 percent I spent ages priming it and there is oil flow through the filter feed.
