Does anyone know where i can get a template for the flat style MDF dashboards?
I remember seeing one a while back but have had no luck recently. Just need dimensions and a template for the curve to make my own custom dash.
a link would be great :grin:
flat dashboards
Steve@RetroDash
, Jan 25 2006 06:09 PM
7 replies to this topic
Posted 25 January 2006 - 06:09 PM
Posted 25 January 2006 - 06:23 PM
These two
http://www.miniproje...n_dashboard.htm
http://www.minifinit...d=diy_dashboard
Dont know if they are useful to you
Posted 25 January 2006 - 06:39 PM
i think theres one or the TMF cd ask guess works :smartass:
Posted 25 January 2006 - 06:53 PM
thankyou lads luv ya
ps the first links dimensions are 30mm smaller in length than the second links dimensions :saywhat:
Posted 25 January 2006 - 07:33 PM
I used the second plan on the first page for mine and it was 2.5cm too short.
Posted 26 January 2006 - 08:40 AM
I just finished my dash last week i started with the template but to be honest thry don't really work.
Do you know anyone with a dash in their mini? Just take it out its only a two minute job and then check the size against your own mini. If the fit is good then there yoir template .
Just trace it on to to your Mdf and cut out!
Here mine
http://www.theminifo...topic=19218&hl=
Here mine
Posted 26 January 2006 - 11:06 AM
WHAT?!!! :saywhat:Do you know anyone with a dash in their mini? Just take it out its only a two minute job
I had to remove the stereo to get into the back to undo the three clamps, then undo the speedo cable then the wiring loom for the clocks then all the wire for the other bits and pieces, horns, cigarette lighter socket, clock....I know I'm slow but it took longer than two minutes!!
Posted 26 January 2006 - 11:56 AM
You know what i mean, I only have to dis connect the stereo than the speedo cable then the wire for the clocks takes bout 5 mins then just whip off the clamps. Ten minute job max! Probably a bit longer because you have the additional horns, cigarette lighter socket, clock.
dont need any of that stuff
