Bhp And How You Got There
24 replies to this topic
#16 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 12 August 2011 - 10:15 PM
Did an engine for my son when he was 17 which is over 15 years ago but the Mini would out run a Pug 1.6 GTi from the lights and keep pulling away from it right up to 90 mph.
Don't know the bhp but heres the spec....
1293 motor
Modified Howley inlet
Modified HIF 44 (doctored needle)
K+N type filter with cold air feed
Modified MG Metro head with 'penny on a stick' valves
LCB with single big bore back box
Lightened flywheel and backplate
Modified distributor (home made)
Kent 286 cam
3.4 diff
Electric fan
I recon 80+ bhp, it would pull 105 on the speedo but prob a bit fast. according to the gearing it was doin 98ish at 6500 ish
Rev counter not calibrated so guess work really :D
Them were the days
#17 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 13 August 2011 - 05:38 AM
145bhp with 116ft revs to 8250rpm 127bhp at wheels
a+ block bored 1380 with omega pistons
en40b steel crank
steel rods with arp fixings,shot peened lightened
4 bolt centre strap
kent 296 cam
belt drive kit
dry decked
7port head fully worked with 37.5 inlets with 31 exhausts
twin 45 webers
ld med full roller rockers
aldon red dizzy
swift tune flywheel backplate grey clutch cover
swift tune sc dog box with sc drops
lsd with sc 3.44 diff
swift tune/maniflow stage 3.5 exhaust manifold
£13,000
Is this the grey J19 car?
#18 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 13 August 2011 - 05:42 AM
149bhp @ 7500rpm
1380cc.
KAD small valve 16 valve cylinder head with belt assembly,
L1 inlet and BD3 exhaust cams, 10.5:1 compression ratio
A+ block with four bolt centre main cap, bored and honed
73.5mm flat top Cosworth or Omega forged pistons
Vandervell Competition engine bearings
A+ Worked crankshaft 81.28 stroke
A+ conrods, with ARP bolts
HP oil pump, water pump
Twin Weber 40 DCOE carburettors
Aldon distributor with Ignitor Electronic ignition
MED Ultralite Steel billet flywheel and backplate
AP grey diaphragm pressure plate and clutch
4-2-1 exhaust manifold
#19 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 13 August 2011 - 08:47 AM
en40b steel crank
4 bolt centre strap
kent 296 cam
belt drive kit
dry decked
twin 45 webers
aldon red dizzy
£13,000
yes
#20 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 13 August 2011 - 09:53 AM
Why do we still do this!! I'm just as bad,I think it is Keith Calver who refers to it as pub talk.Max BHP comes up ,what, 5500 to 6500? How long do our road cars spend at those sort of revs? We all like a bit of acceleration and to accelerate you need to be going slower and then become faster than you were going.TORQUE! is what does that.So what did I do? went along to the local RR'd and asked what BHP I had! Didnt even think about the torque. Oh well. I was happy to find out that my 1275 has 90.5 without being set up;only tested.It has:-
Piper 270 cam
Twin hif 38s /Cone filters/AAA needles
Maniflow LCB, 1 3/4" two silencer straight system
10.8:1 cr
MG Metro head (36/29 valves),Deshrouded the valves A very small amount of opening up of the inlet tracts, fair amount of work to the exhausts,I did fit the 2 extra head studs.
Megajolt ignition, fiddled with alot by myself
Two blade fan- worth 2 hp?
Flywheel lightened and 3.44 fd ratio-not related to the output,just the acceleration.
It has horrible bores and smokes on start up,uses a little oil so in top codition and properly set up maybe would nudge 100 hp?.but I'm impressed with the fact that it pulls well from 2000 and thats very useable
Cost? not sure,paid £30 for the engine,£60 for piston rings and gaskets and £60 for the head, £175 megajolt.£40 for twin inlet manifold,£40 for the extra carb(I already had one 38 from the original engine) Just add up the cost of the other parts plus a head skim.The rest I did myself
Edited by PIGEONTO, 13 August 2011 - 09:55 AM.
#21 nafnaforiginal12
nafnaforiginal12
  • 282 posts
  • Local Club: Cumbria Mini Cruisers
Posted 14 January 2012 - 10:43 PM
en40b steel crank
4 bolt centre strap
kent 296 cam
belt drive kit
dry decked
twin 45 webers
aldon red dizzy
£13,000
yes
Sorry to hijack the thread BUT...
Wow, this car is my desktop photo. One of my favourite reads from mini magazine!! :wub:
#22 thebullet
thebullet
  • 1,337 posts
Posted 14 January 2012 - 10:53 PM
58bhp!
1983 998cc
12g295 head
stage 1
and single HS4 carb.
Standard cam
#23 jackmason
jackmason
  • 522 posts
Posted 15 January 2012 - 06:18 PM
My first 998 had 42bhp and 43ft/lb of torque @ 5150 rpm
It was a 998 with a stage 1 kit had it dynoed before i fitted the stage one kit and it was 36bhp.
Upgraded to a 1380 which on the last dyno run 73bhp and 79.4 ft/lb @ 6556 rpm
Spec...
1380 with powermax pistons,
Kent 276 cam
Duplex timing gear
Balanced crank
Standard 1275 head
Hiff 44 Carb
MG Metro inlet manifold
Electronic Distributor
Center main strap
Pipercross air filter
Standard Box with 3.44 Final drive ratio
Double valve springs
Building up a 1310 atm which will have a weber 40, megajolt, stae 3 head and some bits from my 1380.
#24 dave1293gt
dave1293gt
  • 227 posts
  • Local Club: n/a
Posted 15 January 2012 - 06:38 PM
Mine was last on the rollers at a turbo minis day about 6 years ago, Did 88 @ wheels, 1293 NON turbo
I got there buy purchasing Mike Barretts (MBE) old race car.
Edited by dave1293gt, 15 January 2012 - 06:40 PM.
#25 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 15 January 2012 - 07:31 PM
1330cc
Kent 276 Cam
Stage 3 Head (Approx. it's an old rally design head from the 60's)
MG Metro Dizzy
Minisport Lightened Fly (Std Backplate)
HIF44 Carb
Rebuilt gearbox with 3.44 x-pin diff
On minisport dyno it got 91.5bhp (fly) and 81 lb/ft
Edited by DannyTip, 15 January 2012 - 07:33 PM.
