Posted 11 August 2011 - 11:44 PM
Posted 12 August 2011 - 12:54 AM
Posted 12 August 2011 - 12:27 PM
Hi everyone I building a Zcar buza at the moment and have just picked it up, so will start to swap things over real soon, even with the kids off school, I still want to get in the garage for a play. have to think where the water pipes are going now that the tunnel has been removed. and how best to seal it against water. I welcome your idea
Are these shocker PROTECH as they seem different to others?
This is causing me trouble, as it seems the alloy hole dose not seem big enough for a socket to grip the nut. Is this zcar design fault, or can it just be drilled out?
Edited by edsmini, 12 August 2011 - 12:27 PM.
Posted 12 August 2011 - 03:01 PM
Posted 12 August 2011 - 03:34 PM
Hi everyone I building a Zcar buza at the moment and have just picked it up, so will start to swap things over real soon, even with the kids off school, I still want to get in the garage for a play. have to think where the water pipes are going now that the tunnel has been removed. and how best to seal it against water. I welcome your ideaDSC03418.jpgAre these shocker PROTECH as they seem different to others?This is causing me trouble, as it seems the alloy hole dose not seem big enough for a socket to grip the nut. Is this zcar design fault, or can it just be drilled out?
howdy,
the parts you have are correct but there should be 4 nuts supplied by Zcars which are 16 or 17mm and you need a thin walled socket, i have seen people on here with the same question 3 or 4 times, i would have thought Zcars would have made this a bit easier to follow for customers building up the front ends. im sure when you buy a new ball joint, you get a 19mm headed nut which looks like what you have in the picture.
yes the shockers look like protech.
you would be better putting a tunnel back in the car as you will need to run fuel pipe, battery cables,coolant hoses, and maybe oil pipes. plus you will need to fit gear lever etc.. maybe speak to Zcars and see if they can do a vtec centre console as they look good when fitted. plus you can fit switches on it for lights etc.
Ed
Edited by ZCars Steve, 12 August 2011 - 03:35 PM.
Posted 13 August 2011 - 08:34 PM
howdy,
Ed
Posted 13 August 2011 - 08:40 PM
Looks good, like the colour.
What are the advantages of having a flat floor?
Posted 13 August 2011 - 08:45 PM
Posted 13 August 2011 - 08:48 PM
howdy,
Ed
As Ed says you need a thin walled socket some iron mongers will stock the nuts with the same thread but smaller hex which may also help
We do have the raised tunnels instock for the Vtec feel free to email or call me
we have changed supplier of the dampers so they may not be protech but they are still the correct items
Steve
ZCars
Posted 19 August 2011 - 12:13 AM
Posted 27 September 2011 - 11:06 PM
Posted 07 October 2011 - 10:22 PM
Posted 09 October 2011 - 07:26 PM
