Loads of stuff Major Clearout!
Please Message me with your email address with any questions and I will send you pictures if you would like.
Its all got to go! More to come next week too!
Catalytic COnverter from SPI Mini - 95 with only 30K on the clock £25 + £7.50 P and P
Dark Walnut Dashboard some damage to the lacquer and speedo housing but generally good servicable condition £35 £10 P and P
Headlining - Removed from a 95 SPI, no rips or tears and very clean. In grey and includes the hanging bars £65 £10 P and P
Seat Covers - Rear only in black leatherette, brand new never used £85 £7.50 P and P
Blue alloy Pedal covers, brand new in metal case £10 £5 P and P
Alarm module - Maystar 20-20 removed from a 95 SPI £15 £6.50 P and P
Seam strips x3 in good all round condition £12.50 £6.50 P and P
Door window Regulator Drivers side £10 £7.50 P and P
Door window Regulator Passenger side £10 £7.50 P and P
Positive wire - battery to starter - good condition £15 £6.50 P and P
Brake Servo and pedal box and bracket - Complete system ready to bolt on and use £85 £10 P and P
Clutch Master Cylinder - removed from a 95 SPI, in good working condition £10 £7.50 P and P
Charcoal canister - wing mounted removed from a 95 SPI with bracket and strap £30 £7.50 P and P
Number plate lamp holder with lights and wires in good condition £10 £5 P and P
3 clock dash bracket £7.50 £5 P and P
SPI Downpipe - useful spare, missing rear bracket and some damage to flexi joint braiding but flexi joint seems ok, but easily welded/ repaired £5 £10 P and P
Steering cowl - removed from a 95 SPI in good condition £10 £7.50 P and P
Bonnet Chrome strip - brand new - never used £10 £5.50 P and P
Halogen headlamp x1 - Used but working with bulb £10 £7.50 P and P
Plastic bowl and loom, in good condition £7.50 £5 P and P
Brake compenastor valve - Removed from a 95 SPI in good condition £9 £6 P and P
Pedal box from an 89 mini, no pedals just bare frame with studs intact £10 £5 P and P
Grill ends x2, as new £10 £5 P and P
Front screen seal - Used but perfectly serviceable - the wider variety of seal as fitted to all spi's £10 £5 P and P
Front Screen seal - Brand new, never used or fitted - the wider variety of seal as fitted to all spi's £15 £5 P and P
Boot lid seals - both used but usable £6 £5 P and P
Rear screen seal - Used but perfectly serviceable - £7.50 £5 P and P
Door Seals x2 - Pair of seals in ood condition removed from a 95 SPI - £7.50 £5 P and P
Fresh air bezels - Removed from a 95 SPI in good working condition £15 £5.50 P and P
Shock mounts 10 6.5
Front subframe rear mounts - Genuine rover - Removed from a 95 SPI in good working condition £8.50 £5.50 P and P
SPI Heater hoses - Removed from a 95 SPI in good working condition £6 £3.50 P and P
Horn - Removed from a 95 SPI in good working condition £10 £3.50 P and P
Tower bolts - Removed from a 95 SPI in good working condition £9 £5.50 P and P
Handbrake - Removed from a 95 SPI in good working condition £10 £6.50 P and P
Boot lid hinges - Removed from a 95 SPI in good working condition £10 £3.50 P and P
Interior light - Removed from a 95 SPI in good working condition £8.50 £3.50 P and P
Wiper motor bracket - Removed from a 95 SPI in good working condition £6 £3.50 P and P
Washer Nozzles, stainless steel / chrome, brand new never fitted £5 £4 P and P
Seat mounts x4 - Removed from a 95 SPI in good working condition £8 £5.50 P and P
Boot lid Straps - Removed from a 95 SPI in good working condition £4 £3.75 P and P
Battery securing bits, bar strap and negative wire - Removed from a 95 SPI in good working condition £10 £4.50 P and P
Petrol Cap - Removed from a 95 SPI in good working condition £7.50 £4.50 P and P
Engine steady with bushes (Block mount)- Removed from a 95 SPI in good working condition £7.50 £4.50 P and P
Engine steady with bushes (lower mount)- Removed from a 95 SPI in good working condition £7.50 £4.50 P and P
SPI acc Cable - Removed from a 95 SPI in good working condition £7.50 £3.50 P and P
Pistons spi Cooper 95 (21962 or 3) x 3 - Removed from a 95 SPI in good working condition £5 £10 P and P
Bootlid - In average condition and need of a bit of TLC but generally pretty solid no fittings or fixings included £10 £10 P and P
Pass door in Very Good condition £50 £20 P and P but collection Prefered
Screen wash bottle, from a Mk1 or Mk2 £5 £3.75 P and P
Blanking plate for heater hoses into bulkhead £4 £3.75 P and P
Heatrer knob and cable - Removed from a 95 SPI in good working condition £4 £4.50 P and P
Heater valve - Removed from a 95 SPI in working condition £10 £4.50 P and P
Rad bracket - 1000cc used but perfectly servicable £4 £3.75 P and P
Stereo 4 6.5
stereo 10 6.5
C posts - Removed from a 95 SPI in good working condition £12.50 £4.50 P and P
Visors - Removed from a 95 SPI in good working condition £12.50 £4.50 P and P
Flywheel housing - Removed from a 95 SPI with crank sensor in good working condition £30 £10 P and P
Flywheel housing - Standard size no crank sensor but will fit any mini engine £20 £10 P and P
HIF 44 carb, recently rebuilt and refurbished, great condition ready to use. £45 £7.50 P and P
Rings for 21253 Pistons and also 21962 x3, Boxed and brand new, bought as broke one ring and had to buy a set of 4 rather than just the one set i needed. £25 £5 P and P
Driver door, PM for details £30 £20 Colection Prefered
Pass door, PM for details £15 £20 Colection Prefered
Spotlight mount kit, unused with relay £7.50 £8 p and P
Drivers door, excellent condition, PM for details £65 £20 Colection Prefered
Pass door PM for details £25 £20 Colection Prefered
Dim Dip relay - Removed from a 95 SPI in good working condition £10 £4.50 P and P
Inertia switch - Removed from a 95 SPI in good working condition £10 £4.50 P and P
Fuel filter - Believed to be for a mini - Brand new - £1.50 £3.50
Major Clearout - Everything Must Go!
new_van_man
, Aug 25 2011 09:40 AM
4 replies to this topic
Posted 25 August 2011 - 09:40 AM
Posted 25 August 2011 - 07:26 PM
Pmd
Posted 25 August 2011 - 09:04 PM
could you pm me some pictues of the blue pedal covers??
Karl
Karl
Posted 26 August 2011 - 01:00 AM
ill have the carb! pm'd
Posted 27 August 2011 - 11:36 PM
Alot of those items don't belong in this section. Please move them to the correct section.
