went from Suffolk to Herts on Thursday in Baldrick - a whole bunch of stuff came up... so will try and take it in order. Would welcome your comments, thoughts, advice and so on.
Baldrick is 1985/86 Mini City 1000cc.
Oil Leak/Gear Changes
Okay, on the way to Stevenage I started having trouble changing from 4th to 3rd gear, just wouldnt go in, kinda stuck going into second as second choice, but then afetr another go it went it. This happened a few times. Half way to Stevenage we stopped and checked the engine oil which appeared to be low. So topped up. Noticed drips of oil from the engine onto the floor.. The only different thing I did for the second half of of the journey was not drive down twisty lanes changing gear - just straight and gentle down the main roads. Gears seem fine again for two days and all the way back taking it smooth along main roads only.. Not sure if it was just lazy changing, as from 2nd to 3rd you have to push across to the right, but from 4th to 3rd you just push upwards. Or if it was just low on oil..
Also as I now evidently have a small leak (albeit it did 80 miles today with no apparent drop in engine oil) how dangerous is it to drive, am I looking at new oil seals and I presume some expense as Im faaaar from mechanic .
Choke
Pinged.. Well thats not technically right. The bit on the dash was stuck and then came right out. My Dad (flippin HERO and one time mini owner moons ago) immediately spotted the problem. When you put the choke cable into the outer casing it sticks at a specific point, if you WD40 it and keep shoving little at a time it gets through and them moves freely. Suspiciously the outer cable is marked exactly at that point. Either the garage put it on knowingly, or someone has tried to see if the garage will spot this and change it. After being warned away from the garage via note on my mini, Im now sitting here ultra paranoid and not knowing what to think. Dad and I put the choke cable and stuff back in place and with a little bodging with tape and wire it works better than before. It even started from cold without the choke yesterday!
:saywhat:
The bodge was because when you pull the choke at the dashboard it just moves the whole cable and everything a fair bit before the inner cable actually starts pulling the choke mechanism on the carb. We tied it down and the outer cable stays more still .. I'll have to take a piccie tomorrow .
Air Duct
While he had his head under the bonnet Dad just said "shouldnt there be a hose from the air filter to the engine?"
Reading the Manual, it states about the air filter.Remove the two wing nuts and remove the air filter, and remove the Hot Air Duct (where fitted). Which doesn't really explain bugger all to me. Should I have one, what the hell? etc etc etc
okay ... and lastly - should I take any of this up with the garage where I got it, if they are up to naughties I wont be able to believe a word they say, if they are honest gusy - how do I know.?? Im kinda on my own .. cant decide whether to try and keep baldrick and work through problems or cut my losses. my heart wants to keep him, but if theres dodgies going on Im not bright enough to spot them before they might kill me.
Cant believe how much Ive learnt about engines in the last few months tho!!
