air duct, oil leak, and choke
#16
Posted 30 January 2006 - 10:32 PM
Dave
#17
Posted 30 January 2006 - 11:10 PM
:cool: drop me a line with details if you do come across somethingglad to see things are moving on... think i may have a scrappy old air filte and duct, but not sure... might be able to check weds if need be!
Dave
choke will have to hang on for a bit. Im coming to the end of my work contract, when I get the next one it'll be next on the list.
weirdly baldrick is running better and better the more stuff I find broken/missing on it. Really its a miracle it goes!!
#18
Posted 31 January 2006 - 12:32 PM
oh and the lack of pipe between air filter and engine..
can anyone spot any other obvious stuff that I should be aware of?
Edited by dayzee, 31 January 2006 - 12:33 PM.
#19
Posted 31 January 2006 - 12:34 PM
from what Ive gathered here, that black out cable should run all the way up to the dash.
Posted 31 January 2006 - 06:51 PM
You still have that foam on the bulkhead that soaks up water then rots the metal behind
And looks to have overheated in the past
#21
Posted 31 January 2006 - 08:21 PM
what gave away the overheating? the dodgy colour of the radiator??? mustve been before I got it, because I never see it getting hotter that 1/3 way up the temp gauge.
I suspect the rad lid is easily not put on tight, keep getting splashes on the bonnet after driving (in the dry) and a possible leak where the pipe is - need to tighten the clip.
#22
Posted 31 January 2006 - 11:45 PM
so ripping out the foam is a good idea??? sounds like something I could doooo
But this will increase notice inside the cabin but not by much
Would get used to it after a while
If you do find any rust clean off with wire brush / sand paper back to bare metal
and paint with a few coats of hammerite (what i've done)
What gave it away was the brown ish colour around the rad
Also means there is a lot of rust in the system or the coolant hasn’t been changed for a while (every 2 years)
do yo have a pipe on the top of the rads overflow that runs down the back? (see pic near wiper motor)
he splashes could be the coolant expanding and coming out of the overflow near the radiator cap
#23
Posted 01 February 2006 - 06:50 AM
Ill have another look at the rad.. thanks for the hints.. !!do yo have a pipe on the top of the rads overflow that runs down the back? (see pic near wiper motor)
#24
Posted 01 February 2006 - 11:52 AM
#25
Posted 01 February 2006 - 06:49 PM
thx for the hint... and yeah, new choke cable and outer is next on the ebay list after payday - now I have one that works almost right, the engine is being MUCH better at starting up and not stalling.. figure it must have had the choke stuck on quite alot.The picture of your choke cable actually looks OK, it's just the plastic wraper that's come away not the actual outer cable. You will get better choke operation if you straighten out the run of the cable, pull it back into the car and lift it over that heater pipe before you put it back. Although if you're having trouble it may be best to replace it anyway, just run the new one as straight as you can.
PS: just noticed your Red Bull ignition coil!! I want to Broon Ale one..
:cool:
Edited by dayzee, 01 February 2006 - 06:51 PM.
#26
Posted 04 February 2006 - 05:02 PM
I do have the overflow pipe (at least thats one thing it does have) but I think I have a leak still - probably the main pipe by the looks of it. I drove it today and stoppped and popped the bonnet and it was STEEEEAMINdo yo have a pipe on the top of the rads overflow that runs down the back? (see pic near wiper motor)
