My 1330
29 replies to this topic
#1 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 30 August 2011 - 09:01 PM
Right this winter the mini is coming from up from the barn and into the garage as dad has given it to me for a work shop
the plans are for a new engine as this is the only thing letting the car down
the plan is for a 1330 engine:
work:
engine re-bore +0.60
clean oil ways and renew oil gallery plugs
lap in new pressure valve
regrind journals on crank
balance crank, pistons and flywheel
Engine will also be dry decked.
Cylinder head:
purchased a slark racing stage 3 head:
ported and polished
modified chambers
bronze guides
double valve springs
35.7 inlet and 31mm exhaust
Cam:
kent 286
Carbs:
thought i would go for something a bit different so im going Yamaha R6 bike carbs with a 38mm choke.
with a "bit" of modification i should be able to get them onto a 1.5" su manifold.
Transmission:
standard box
X-pin diff
s/c drop gears
looking forward to the winter build :) should be interesting
Not sure what sort of power I will get from this build? If anyone want to hazard a guess feel free :)
I'm
In the process of looking round for se quotes to compare against each other for the above engine work so if any one can recommend or if you your self are part of a firm who can quote me on the work please do contact me :)
Cheers Hughzy.
#2 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 30 August 2011 - 09:02 PM
Pictures ?
#3 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 30 August 2011 - 09:15 PM
Pictures ?
No pictures just yet, should received head tomorrow fingers crossed.
#4 Andrew O
Andrew O
  • 1,425 posts
Keep us posted
#5 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 30 August 2011 - 09:19 PM
I will do my absolute best.
#6 MrBounce
MrBounce
  • 2,660 posts
Posted 31 August 2011 - 09:36 PM
Sounds like a nice idea. Depending on how well the carbs work I would guess at that making a healthy 85-90-odd horsepower. What are your plans for ignition? Dizzy? Megajolt?
And yes, pics please :thumbsup:
#7 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 31 August 2011 - 10:43 PM
Sounds good, i would drop benross of tm and see what bits he can do for you. Med is another one for good quality engines.
#8 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 01 September 2011 - 05:30 AM
This sounds very similar as to what I was going to do to my 1330, although I'm going down the turbo route now. I was looking (and was told), I'd get between 90-100BHP :)
#9 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 02 September 2011 - 05:24 PM
Ok right ok what does benross specialise in?
#10 Leon_mini
Leon_mini
  • 166 posts
Posted 03 September 2011 - 09:09 PM
Benross specilises in turbo engines and are well known/respected on the turbo forum, also try turbo phil on there, does N/A heads
#11 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 11 September 2011 - 09:08 AM
Little update, These are The bike carbs I purchased. They are yamaha R6 38mm carbs and they were a bargain. :biggrin:
These are the carbs modified to fit the su manifold which is also custom as you will see below. To do this only 2 out the 4 were need to first had to split them and get the spacing spot on to suit the rubber mounts and manifold, also the extension on the throttle linkage, balancing pipe, fuel in and fuel return lines :tongue2:
Here's the new cylinder head. It's a slark racing stage 3 head 35.7mm exhaust and 31mm inlet fitted with comp everything. :biggrin:
Also my modification to my manifold. :smile:
So watch this space people :).
Edited by hughzy69, 11 September 2011 - 09:14 AM.
#12 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 12 September 2011 - 05:30 PM
Did another couple of hours in my girlfriends garage tonight.
Inlet rubber came for the carbs on Saturday so fitted those to manifold, also re spaced the carbs to suit.
They look pretty cool bolted to the head don't you think?
Main concern are they going to get under the bonnet?
#13 Andrew O
Andrew O
  • 1,425 posts
Posted 12 September 2011 - 06:10 PM
Your cylinder head is mini porn in my opinion :D
#14 hughzy69
hughzy69
  • 271 posts
  • Local Club: UBMC
Posted 12 September 2011 - 07:34 PM
Haha cheers, I'm hoping it's going to be a nice improvement to the std 1275 :)
#15 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 13 September 2011 - 04:33 PM
I built an engine to this spec, it was very nippy. Around the 95bhp mark. Love the bike carbs.
If they dont fit under the bonnet, set the bonnet on bonnet pins and have it lifted up at the back? Might be something to think about, but i think youll be ok.
