i was think of doing that but im only 17 :sad:
what can i do. HELP!!
davexdavexdave
, Jan 29 2006 03:17 PM
20 replies to this topic
#16
Posted 29 January 2006 - 04:23 PM
#17
Posted 29 January 2006 - 05:05 PM
so what has the clutch done?
dave
dave
#18
Posted 29 January 2006 - 10:47 PM
the presure plate has gone apparently
#19
Posted 30 January 2006 - 12:18 AM
I seriously doubt that, the pressure plate's a lump of cast iron. The friction plate is a more likely culprit (and a lot cheaper), what is it doing exactly when you try to use it?
#20
Posted 30 January 2006 - 01:04 AM
sounds like the diagnosis of the recovery man...
to be honest you will need to open it up to see whats happened.
But before then: what are the symptoms as if you've 'lost the clutch' - it could be something as simple as the hydraulics not working....
TTFN,
Dave
#21
Posted 30 January 2006 - 10:44 AM
thats what i was driving at, does the car still drive, does it have any clutch or has the pedal gone solid and u have no drive, a discrption of fault helps alot more than no clutch
dave
dave
