A series box onto turbo engine?
26 replies to this topic
#16 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2006 - 11:32 PM
no.2
#17 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2006 - 11:33 PM
no 3
#18 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2006 - 11:40 PM
And that is an A series ( small idler ) box, manual with a SCCR Gearset, and you can see from the idler face on the gearbox case, it's had it...
Not sure from them but could also be a remote box, but seems to have some added bits in the other end ???
#19 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 31 January 2006 - 12:10 AM
i just bought the box for the sc cr gear set as i was planning to rebuild it but think i may of bitten off more than i can chew.
The box is at work just now so ill take more pics of it tomorrow and get them up
Dan
#20 icklemini
icklemini
  • 2,982 posts
Posted 31 January 2006 - 02:01 PM
are you sure?
Can you get straight cut automatic gears? as the gears are definantly stright cut but i was told in an autobox so now a little confused. The box looks a little modified with bits grinded off it here there and everywhere. Ill try get some pics and post them.
Yes i am sure.
No straight cut auto gears. They are pretty unloved boxes...
The photos are from a pre A+ small idler box, have you the laygear as well to go with it?
#21 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 January 2006 - 06:46 PM
There's pretty much no 'gears' as you would normally understand them in an autobox anyway! The Mini autobox is kind of a cross between a diff and a Laycock overdrive, it's a pretty remarkable design.
That gearcase is a bit tired in the idler gear department as GW says but you could rescue it by using a roller bearing conversion for the idler couldn't you GW?
#22 icklemini
icklemini
  • 2,982 posts
Posted 31 January 2006 - 07:48 PM
could rescue it by getting it skimmed...
if your desparate for a small-idler-bearing case i'm tripping over the things!! Can have one FOC!!
TTFN,
Dave
#23 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 January 2006 - 11:35 PM
You could go the timken route, but at 150 for the idler, let alone the cost of the primary and input gear aswell.. sledge hammer and walnut come to mind..
If it were a decent 3 stud A+ then maybe worth holding onto incase of emergency, but same with Dave... I've got A series cases stacked up outside
If I had not had a rush on in January, I would have built some A's up and taken them to Bingley to flog off just to get them out me way !
#24 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 February 2006 - 11:50 AM
I have received some more pictures from Daniel, and will post below.
As suspected the box is a remote, and have suggested that it may be better to shy away from that if it's to be used in a turbo application, mainly because of the size of the nose on the 3rd motion and the smaller Pinion retaining nut, but also the fact that it's a weaker case than the A+, and a small idler on a turbo is not the ideal situation.
Comments from others invited...
#25 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 February 2006 - 11:51 AM
pic 2
#26 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
pic 3
#27 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 February 2006 - 11:52 AM
pic 4
