My Leak mission!!!
BlAck0ut
, Jan 29 2006 06:45 PM
11 replies to this topic
Posted 29 January 2006 - 06:45 PM
Ok my mini leaks oil in several places, what im wanting to do is try and replace all the parts in a mini engine bay that is likely too leak oil.
So far i know the gearbox selector leaks aswell as the dipstick.
Any ideas where else it could be leaking? and how i could irradicate these problems?
Cheerzo
Cheerzo
Posted 29 January 2006 - 06:47 PM
oil filter, rocker cover gasket
Posted 29 January 2006 - 06:59 PM
done the rocker cover gasket
Posted 29 January 2006 - 07:02 PM
:erm: thats me all out of ideas sorry, ill leave it up to the pro's to fill in the rest!!!
clutch housing (if clutch oil seal has gone), transfer gear housing, timing chain gasket, timing chain crank seal, output shaft (pot joint) seals, output shaft gaskets, diff gasket, speedo drive gasket, oil filter housing.
Most likely will be the output shaft seals and gaskets, as well as the selector shaft.
hehe...
Posted 29 January 2006 - 07:19 PM
I was just about to say all that but he beat me 2 it!!!!!! :smartass:
Posted 29 January 2006 - 09:54 PM
dipstick shouldnt leak unless you're building up crankcase pressure, which, by the way is bad. check your crankcase breather filter/hoses (depending which you have),
Dave
Dave
Posted 29 January 2006 - 09:58 PM
I got an oil leak but have no clue where from.. although I suspect it may be worse when I change gears alot.. so transmission..?? but that list back there just freaked me right out.. !!
:saywhat:
:saywhat:
Posted 29 January 2006 - 10:06 PM
Or the teeny tiny little plate or seal on and around the gear selector shaft at the back of the engine...
by the way. all minis leak oil, it's a design feature to stop the front subframe from rusting!
Posted 29 January 2006 - 10:15 PM
I like your technical jargon ... !!Or the teeny tiny little plate or seal on and around the gear selector shaft at the back of the engine...
theres only tiny drips, and i think more when I use the gears more - havent tested it fully yet (and pooing my pants thinking about it).. luckily Im now carrying half a service station in the mini - no room for passengers...
Posted 29 January 2006 - 10:23 PM
The dipstick was leaking because there was no o ring and the engines two breathers where connected together lol!! they arnt anymore and ive got some filters on their way
