Piston To Bore Clearance 1330 ?
ckendall
, Sep 15 2011 02:29 PM
22 replies to this topic
#16
Posted 16 September 2011 - 07:05 AM
The numbers on top of the piston were 21251+.060 if thats any help
#17
Posted 16 September 2011 - 09:28 AM
With the pistons about mid way up/down the bore is there a lip at the top of the bore, ie if you run your finger up the bore does it suddenly deviate.... if there is a step then work may need to be done if not then I presume this engine used to run ok so what has changed ??
#18
Posted 16 September 2011 - 10:21 AM
The piston size is the bore size really, so you can measure the bore above the pistons with a bore gauge. If it's worn you wouldn't even need to know the size, it's extremely unlikely they'd wear evenly. Since it wasn't new I suppose there's the possibility that it was put together with second hand pistons.
Then again it could be any number of things, failing big ends rob power and rattle.
#19
Posted 16 September 2011 - 10:22 AM
I've just checked the bores and they all seem smooth all the way up ???
As for what changed no idea
I bought the lump second hand it runs fine at tick over theres just no power when under load
and theres the rattle from the bottom end ??
#20
Posted 16 September 2011 - 10:49 AM
rattles from the bottom end are never good news
#21
Posted 16 September 2011 - 10:59 AM
Any idea of cost ??
#22
Posted 16 September 2011 - 11:49 AM
Regrind on the crank £80-£90 and new shells...£60-£70. so £150...roughly...But you will need to take it apart and rebuild it yourself for that....If your sending the block away then I guess it would be wise to phone around and get some quotes..I think there is a phone number not that far away^^^^^^^^
Edited by AndyMiniMad., 16 September 2011 - 11:53 AM.
#23
Posted 16 September 2011 - 03:02 PM
Thanks Andy
I'll be giving the above number a call soon
