Using A Mini As A Track Car? Pros And Cons
Posted 20 September 2011 - 04:43 PM
My opinion is that they handle really well are cheap to maintain and i know them inside out. Parts are easy to get hold of and can easily kit it out with handling and braking increases very cheaply. The downside is the crappy engine and wheel bearings just don't seem up for it. I need to keep it small as i want to tow it to track and the smaller the better so BMW or the likes is out of the question but what other hatchbacks out there would be fit for purpose?
Posted 20 September 2011 - 04:49 PM
easy to make lighter, cheap to buy, parts are cheap, handle brilliantly,
cons i cant personally see/think of any, except the urge to want to go fast but basically a completely stripped out mini is going to be very competetive and give you a buzz even with just a 1275 engine..
any car you chose as soon as you have felt that you have meet the need for speed you will non the less want to go faster! and the options of making a mini go faster are endless!but you will find yourself spending more and more money!
Posted 20 September 2011 - 04:50 PM
Pro:
Cheap parts/tyres
Fun
Good handling
Easily and cheaply modified.
Cons:
Reliability
Slow straight line speed (but dont let that put you off)
My biggest problem is trying to get the oil to stay in the car.
As you can imagine, oil on a track is very bad.
MX-5 is one of the most popular track cars I see.
But also things like saxos, clios and 106 gtis seem very popular and quick.
Posted 20 September 2011 - 04:51 PM
Posted 20 September 2011 - 04:55 PM
Power isn't everything on track, but my 1380 was faster, and it still needs to be faster again.
Posted 20 September 2011 - 05:00 PM
Posted 20 September 2011 - 05:12 PM
First off pros and cons
Pro:
Cheap parts/tyres
Fun
Good handling
Cons:
Reliability
Thats my problem exactly, don't get me wrong i love the mini but am i barking up the wrong tree entire when you start considering the other hot hatches out there. I know everyone says that mx-5 are hairdressers cars and that that is only said by people who don't own them but ITS A HAIRDRESSERS CAR
Posted 20 September 2011 - 05:22 PM
If you're after power to make them competitive, then reliability is the real problem of a trackday mini, plan to rebuild the engine on regular basis. But parts are very cheap when compared to modern cars.
Edited by jaydee, 20 September 2011 - 05:23 PM.
Posted 20 September 2011 - 09:16 PM
Posted 20 September 2011 - 09:36 PM
whilst of course a track day isnt about passing every car on track, if your always having to drive over to the side to avoid other drivers pouncing you from behind, your concentrating on something else other than having fun.
Drove my mini round combe last year, that was a blast. compaired to some other mini's mines got a decent pace and being that it was with minis and not things like lotus' or porshes its alot more easy going not having to look behind all the time... even the binis were slow
Posted 20 September 2011 - 09:43 PM
You can pick up much better and faster track cars for less, but then won't be as fun or have the heritage of the Mini.
If you love Minis then I'd say go for it, if you just want to go fast around a track for cheap then look elsewhere.
Posted 21 September 2011 - 06:49 AM
Mini's hold the road well (although I have had a few offs, including rolling it a few weeks back), and I dont think you can get a car for the same money that will put such a smile on your face. If you keep on top of the work you should have no problems. But as with all track cars they are pushed a lot harder than they were intended so things will fail quicker than on the road, but once you have found the weak points you can do something about them.
If its for use only on a track though I would put a full cage in it, as you can still have a good shunt at low speeds.
Posted 21 September 2011 - 10:26 AM
A Pug 205 GTi could be good fun.
I think it could be a case of just looking around to see what is available. Something might jump out at you as a good option.
I would love a track Mini, or track car in general.
What about a Caterham or something like that? You could pick up a kit car fairly cheap one somewhere, and you could do so much to it. Plus they are light and easily moved around.
Posted 21 September 2011 - 11:07 AM
