exactly whats wrong????????
Posted 31 January 2006 - 05:31 PM
Posted 31 January 2006 - 05:49 PM
Posted 31 January 2006 - 07:06 PM
What's broken?
How does it feel? If the spring was snapped then there'd be no feel to the clutch at all and you would be able to push the pedal to the floor with almost no resistance. Also there would be an almighty racket and the noise of things breaking expensively when you turn the engine over.
I find it unlikely that the spring has broken, when they do break they tend to take bits of the clutch cover with them on their way out of the car. You say that you can start the car with the box in gear and the clutch disengaged without the car moving. That means the clutch itself is actually working. I reckon it's your slave cylinder that's gone. They are very well known for doing this at the worst time. What I would do myself if I absolutely had to have it working this weekend would be to buy all the parts you might need (slave cylinder, 3 piece clutch kit, clutch hose, clutch fluid, clutch arm, plunger, graphite grease etc.) and keep the receipts and don't open anything you don't need to. Start the work by supporting the engine on blocks and remove the left engine mount and clutch cover. Now you'll be able to see if the clutch is still in one piece, if it is then check out the hydraulics and release system. Change over the cylinder and put it all back together to see if it works. If it does then return the unused stuff, if not then change the clutch. The clutch kit is by far the most expensive thing you'll be buying so if you don't use that you'll save quite a lot of cash. You'll need quite a bit of time if you haven't done it before and some tools that aren't everyday items.
Check out Guessworks excellent FAQ on clutches. It's one of the first he did so it'll be at the back of the list I should think.
If your car has it's original engine and gearbox then you have a Verto/Valeo type clutch.
Posted 31 January 2006 - 07:41 PM
Posted 31 January 2006 - 07:46 PM
Posted 31 January 2006 - 08:20 PM
Thanks mate.
Posted 31 January 2006 - 09:12 PM
The only way you can be certain about what's wrong with it is to take it apart and find out. My opinion is that it isn't the spring. If the spring was failed then it would still be possible to de-clutch. It would be clutch engagement that would give the problem not disengagement. But then I could be wrong. I'll see if I can get someone else to add their opinion.
Green Flag geeza means the spring, on most cars the spring and pressure plate are part of the same unit. Mini's are different, the clutch is inside out. It's just terminology. How often do you think he deals with hydraulic clutches these days? Almost every car in the world has a cable clutch now.
The return stop is only fitted to the pre-Verto clutch system, you don't have one.
Posted 31 January 2006 - 09:44 PM
Posted 31 January 2006 - 10:55 PM
So, the failure is in the operating mechanism..
Have you checked the fluid level, and bled the system through... ??
Once you have done that, do as Dan has suggested and see how much movement of the plunger there is, it should move from it's rested position to a point where the stop nuts hit the 'wok', if it does not then the slave cylinder is not pushing far enough.
If so, then it's likely that there is a failure in the hydralics.
If you do get full movement, and the clutch is still not disengaging then it could be the clutch release bearing which has collapsed, and is not applying the pressure to the clutch, this is a very simple job as it's only held on by a rubber O ring but will necessitate the removal of the clutch cover (wok) from the side of the engine.. can be done in car and is not too fiddly, as explained above.
I hope that eases you suspicions...
Posted 31 January 2006 - 11:37 PM
dave
Posted 31 January 2006 - 11:49 PM
Let me think about it for a while and i'll get back to you :cheese:
Edit: Confusing as in clutch slipping and then not dissengaging fully
Edited by Mini Sprocket, 01 February 2006 - 12:12 AM.
Posted 31 January 2006 - 11:51 PM
Holly C**p, thats exactly what i was thinkingdid have one the other week that killed the top hat bit of the clutch, that was interesting
dave
Siezed release bearing causing excesive wear on the thrust sleave :smartass:
What ever it is I recon its a take it apart and see.
Posted 31 January 2006 - 11:55 PM
Posted 01 February 2006 - 06:35 AM
Engine off select any gear fine and depress/release clutch
Engine on depress and release clutch but not select gear,
You could select gear and start the car and the car would move slightley with clutch depressed,
Took it to bits and there is 6 or so springs inside the clutch and they were shagged.
Good luck
Let us know how you get on.
Posted 01 February 2006 - 12:07 PM
Dave,
If you are going to buy all the parts you might need as above then also get an extra CRB (clutch release bearing) and its retaining O-ring and a new top hat thrust sleeve in case it's these parts you need to change. Then you can take back the complete clutch kit unopened if you don't need to touch the clutch (as you probably won't), or take back the extra CRB if you do replace the whole lot. You'll have all the parts you may need and still spend only what you need to.
