Well here it goes, my first Mini Restoration!
I recently bought a nice little 1981 Mini HL from my girlfriends cousin.
It seems really quite sound...
It has rust to the a-panel which will need cutting out and replacing with a new one, but apart from that its pretty sound. All of the usual problem areas seem pretty good like the subframes, boot floor, sills, inner wings, scuttle etc. It also seems mechanically sound as it drives OK although it does not have tax and MOT.
Some little toe-rags rolled it on its side causing damage to the drivers door and wing mirror but that should be easily sorted. He was caught and given community service so there was some justice!
My plans are quite simple really...
Exterior:
Replace O/S a-panel.
Replace/ repair drivers door.
Strip ghastly paint.
Re-spray.
10x6" wheels
Nice arches.
Interior:
Generally smarten it up basically.
So here it goes...
How it looked when I picked it up :
Then i spent a couple of weeks sorting my Nannas garage out which now looks like this:
And then the Mini in its new home:
Tonight I made the first move and took a wire wheel to the a panel to see how much of it would come off to see if I could see behind it. It seems that the panel behind the a-panel may need a very small repair where it meets the door.
I also had a little go at the scuttle panel as I saw a very small patch of surface rust forming and wanted to make sure that it wasn't held together with filler! I was relived to find that it was all sound metal with no bodge jobs to be seen!
Also here is a photo showing the damage to the door:
And another photo just for good measure:
Thanks for looking and i will try to keep this updated!
Regards, Marc.
Edited by Marc_mcq, 24 August 2012 - 07:48 AM.
