M.o.t Failure :(
39 replies to this topic
#1 oliver122
oliver122
  • 1,007 posts
Posted 10 October 2011 - 12:34 PM
well mini went for m.o.t today and it failed
failure list (red paper):
1)nearside front track road end ball joint has excessive play ( had a new track rod end about a month ago)
2)nearside front suspension has excessive play in lower suspension ball joint **dangerous**
3)nearside front suspension has excessive play in upper suspension ball joint **dangerous**
4)offside front (front mounting) subframe attachment rubber mounting bonding deteriorated resulting in excessive movement **dangerous**
5)nearside front (rear mounting) subframe attachment rubber mounting bonding deteriorated resulting in excessive movement
6)offside front (rear mounting) subframe attachment rubber mounting bonding deteriorated resulting in excessive movement
7)exhaust emissions carbon monoxide content excessive
orange paper :
measurment
brake advisories: rbt front brake imbalance 22%
adivosry items:
8)front exhaust has a minor leak of exhaust gasses
9)front brakes only just met the front brake imbalance requirements. it would appear requires ajustment or repair(its had new calipers , dics and pads on not long ago )
10)suspension joint nearside lowerdust coversplit/missing
11)oil leak **dangerous**
12)nearside knuckle joint boot insecure
13)vechile has had numerous repairs and its heavily undersealed ( Posted Image i ony put one can of wax oil on)
14)offside front lower bumb stop missing
15)nearside front lower bump stop missing
16)unable to carry out full inspection in boot area due to modifications / cover panels fitted ( boot lining kit )
is it a big job to do the subframe mounts ?
#2 coopdog
coopdog
  • 4,506 posts
Posted 10 October 2011 - 12:41 PM
you got a good fail there :L
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 October 2011 - 12:49 PM
The subframe mounts are pretty easy to be honest. If you've got a friend and an hour to spare you'll soon get them done.
#4 oliver122
oliver122
  • 1,007 posts
Posted 10 October 2011 - 12:52 PM
i know XD haha , and yea i have an uncle with a 2 post car ramp , would it be worth changing to poly bush's or solid mounts do you think ?
Edited by oliver122, 10 October 2011 - 12:56 PM.
#5 madboy
madboy
  • 272 posts
Posted 10 October 2011 - 06:01 PM
sounds to me their lacking in work and was hoping you would leave it for repair, put the kettle on boys we got an easy day ahead!!!!!!!!!!!!!!! :tumble:
#6 CaptainBland08
CaptainBland08
  • 675 posts
Posted 10 October 2011 - 06:44 PM
sounds like the same to me as well! lol to be perfectly fair theres not one difficult job on that list... just dirty ones... have fun with it:D
#7 jbs.998
jbs.998
    Previously known as Rockabillypsychosis
  • 928 posts
Posted 10 October 2011 - 06:48 PM
I would change to solid subframe mounts.
One of the best things I have done to mine.
#8 oliver122
oliver122
  • 1,007 posts
Posted 10 October 2011 - 07:08 PM
i was thinking the same , it made me laugh the heavily underseald part , like its a bad thing for a mini xD , what differance's does it make upgrading to solid mounts? also what mounts did you change to solid , as i have an idea how you would go about changing the lower ones but the tower ones im not to sure ?
Edited by oliver122, 10 October 2011 - 07:13 PM.
#9 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 10 October 2011 - 07:37 PM
well you certainly failed in style!
#10 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 10 October 2011 - 08:16 PM
Number 16 seems a bit of a farce too, I didn't know they inspect for rust through the boot pretty much every car has a carpet in the boot, what's wrong with looking up when over the pit?
#11 racingbob
racingbob
  • 3,061 posts
Posted 10 October 2011 - 08:38 PM
i have new ordinary mounts on bottom rear subframe and yellow poly on tower mounts cars fine
#12 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 10 October 2011 - 08:40 PM
i was thinking the same its rediculous.
id be tempted to agree with madboy, they seem to want money for old rope.
#13 Spud_133
Spud_133
  • 1,689 posts
Posted 10 October 2011 - 08:45 PM
It's a shame they have to do things like this, in the garage I work at, is really quiet, but we don't 'make' work.
#14 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 October 2011 - 08:47 PM
I love this type of response whenever someone fails a car.
Item 16, if there's a bootlining kit, there are several areas in the boot that the tester cannot inspect, the rear of the seat back being just one example. All he's done is note as an advisory that he can't see it to properly inspect it. Kind of the same thing with the underseal. If he can't see the seams around patches, but know there are areas that have been repaired, then he's noted that he can't see how good the repairs are. It's his name on the certificate, so he's totally entitled to make notes like that.
The rest of it, is it really that hard to believe that it's genuine? Most garages wouldn't want the work, I doubt they've got a load of stock of subframe mounts.
#15 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 10 October 2011 - 08:49 PM
I'd have thought you got away quite lightly, theres not that much there to be honest.
As Matt says, the tester is just covering himself, he hasn't failed it for silly reasons just done the sensible thing and advised.
