Converting Standard Mini Switches To Led Toggle Switches Help?
20 replies to this topic
#1 colinjames11
colinjames11
  • 34 posts
Posted 11 October 2011 - 10:56 AM
Hi people basicly i just bought some red led toggle switches, now as i was about to put them in i noticed pretty much all the switches have 4 wires coming in, where as my new ones have the ground (earth), input power and output power. So what are the 4 wires on the old ones, im guessing possibly the old ones had to have their own feed for power? if so or not anyone able to clue me up??
here are the switches in question:
http://www.ebay.co.u...984.m1497.l2648
Im also going to put on a push start button here it is:
http://www.ebay.co.u...984.m1497.l2649
any ideas how to do this? and finally ive bought a aluminium surround for the switches but i cant figure how to get the choke and heater cable button things, well cable pulls off any help many thanks mini people :)
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 11 October 2011 - 11:20 AM
Most of the switches on the mini are multi-pole and also multi-position...
The only one you can realistically change for a single pole off-on switch is the rear demister...
The headlight switch is an off-on-on switch, and has to control two circuits, the side and head lights, and also when the headlights are on then the side light are also required to be on..
The Hazard is an on-on switch, so when in the 'off' position it's actually on and sending power to the indicator circuit, and in the 'on' position it cuts power to the indicator circuit and connects the power to both left and right indicators from a permanent 12v feed and the hazard flasher.
The brake test is not so much a switch as a lamp with a test, the switch just makes the circuit live to test the bulb is working, but in normal condition the circuit is live.
Finally the fog light switch is an off-on, but receives it's power from the side light circuit...
So, if you want to change from the std switches to toggles, the you will need two off-on switches, a momentary on-on switch, and two multi-pole switches, one being an on-on and the other being an off-on-on ( 3 position switch - but you can do this with two off-on multipole switches if necessary )
#3 colinjames11
colinjames11
  • 34 posts
Posted 11 October 2011 - 12:46 PM
ah cheers for that info right seems i need to re think this a little more then just buy some pretty switches, ok im back to the drawing board i dont think you can buy alternate of these switches which kinda sucks but i shall look around and try to update this project as it comes along cheers again.
#4 freshairmini
freshairmini
  • 1,718 posts
Posted 11 October 2011 - 01:55 PM
Im sure you could do multi pole switches with the LED's, as I know you can get multi pole standard toggle switches.
#5 evansisgreat
evansisgreat
  • 1,140 posts
  • Local Club: Not yet
Posted 11 October 2011 - 02:34 PM
I've looked but never found multi pole L.E.D. toggle switches.
#6 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 11 October 2011 - 07:44 PM
It can be done, but with a bit of tricky circuit work.
I upgraded to the MPI stalks, with lost me the headlight switch problem.
I left out the brake test switch, as this is now done via a warning light, just like you get on modern cars.
The rear fog is done with a normal toggle switch.
The rear demist can be done with a toggle
The hazard switch can be done with a toggle, with the help from a number of relays - there is a circuit diagram on here somewhere, its what i used for this circuit - it works.
As for the choke and heater cables, first you need to disconnect them from the engine end, then inside the car, you'll find 2 small nuts holding the switch panel in place, right round the back of it. Get on your back and get your head round there... the first time isn't easy!
#7 furiousjim
furiousjim
  • 151 posts
Posted 11 October 2011 - 10:14 PM
I'd like to see your dash/switch set up Screech, if it's posted somewhere else point me in the right direction!
#8 screech
screech
  • 3,136 posts
Posted 13 October 2011 - 08:01 PM
I dont think theres anything on here, il take some pics at the weekend when i pop to my parents.
#9 Brams96
Brams96
  • 2,308 posts
Posted 14 October 2011 - 05:42 AM
This is a diagram from someone on here (can't remember who now) that rewired their switches, I hope they don't mind me sharing it :)
#10 screech
screech
  • 3,136 posts
Posted 18 October 2011 - 07:20 PM
Here's a couple of pics of my switch set up. Ignore the mess and dust and lack of dash, it's in mid rebuild!!
#11 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 19 October 2011 - 04:33 PM
What's the sport button do :gimme:
#12 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 19 October 2011 - 04:49 PM
thats exactly what i was about to type before i saw your post.
#13 screech
screech
  • 3,136 posts
Posted 19 October 2011 - 05:21 PM
It changes the map slightly, and pushes the rev limiter a little bit higher :-
#14 maggies_minder
maggies_minder
  • 4,393 posts
Posted 19 October 2011 - 05:22 PM
oooooowwwwwww very smart. i like that a lot.
#15 loobylooby
loobylooby
  • 76 posts
Posted 27 November 2011 - 11:53 PM
strugling to understand that wiring diagram brams:/...
