Advantages Of Pressed Steel Rockers And Hif 38 Over Standard
Posted 11 October 2011 - 01:01 PM
and how are why better ?
p.s sorry if its a stupid question
Posted 11 October 2011 - 01:40 PM
Posted 11 October 2011 - 02:17 PM
also what advantages are there with using a hif 38?
Posted 11 October 2011 - 04:27 PM
Since you are contemplating changing to an HIF38, I assume your engine came with a HS4 carb. The two carbs will breath about the same so changing the carb isn't going to make much difference. However, you could change the needle in the carb you have to perhaps get a bit more out of your engine.
Posted 11 October 2011 - 04:55 PM
and thanks mra minis
Posted 11 October 2011 - 05:10 PM
Jake
Posted 11 October 2011 - 05:21 PM
shouldn't really need change the needle if you have a stage 1 kit, they normally come with a different needle to standard anyway.
shouldnt but i dont really trust the guy i bought the mini from
#It may be worth getting a rolling road tune, this should include a re-profiling of the needle to match the engine, also they will sort out the timing and mixture etc to really get the most from your engine. As most standard needles will be fairly close, but this will get it spot on, which should help improve power and economy. So if you do many miles you will make up the cost of the tune over time.
Jake
i think this is what i will do once its on the road just too make sure everythings ok
once again thanks for all the advice
Posted 11 October 2011 - 05:24 PM
Posted 11 October 2011 - 05:35 PM
Posted 11 October 2011 - 06:51 PM
Posted 11 October 2011 - 07:00 PM
The pressed steel ones are certainly lighter, but most people stopped using them when the original 'S' forged rockers arrived.
Posted 11 October 2011 - 07:42 PM
Stick in an AAA needle - with 3 in 1 oil in the damper, advance the timing till it 'pinks' - then take it back slightly. Now go spend the RR money on something useful.......
This man speaks sense.
I only ever took my car to a RR once. I paid £120 for him to gain 0.3bhp over what i could myself with my own tools and ear.
Yes alright i do have a few good tools like the genuine SU balancer etc but yeah. Waste of money
When i put the full rally head on it i just looked up in vizard the rich mix for my car put those needles/springs in and it was much better. Obviously.
Then just some fine tuning on the mixture by looking at different revs and dropped the needle to sort it out then had a quick fiddle on the mix screw and perfect.
Fuels beautifully across the rev range in all gears
Oh and back to the OP. Dont change your rockers unless you go for the MED 1.3.1 ones. but thatll give you a whack in the wallet.
Skip this and the £220~ you save will go a long way to a recon 12G295 head.
The HIF38 will give you an increase but if your plans are to put a big valve head (Either a cooper or 1275) then you should go for a HIF44 instead really.
Or even better than both of these get Twin HS2's modified as per Vizard.
Jesus
Edited by twrminisport, 11 October 2011 - 07:45 PM.
Posted 11 October 2011 - 08:30 PM
Posted 11 October 2011 - 10:17 PM
