Advantages Of Pressed Steel Rockers And Hif 38 Over Standard
16 replies to this topic
#16 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 October 2011 - 02:52 AM
The HIF is downdraught so no lean-off issues when hard cornering.
Downdraught? Most SUs would be characterized as side-draught. A downdraught carb would be something like a Weber DGV.
However, the HIF has the integrated float bowl below the jet which is indeed less subject to leaning out during cornering.
#17 MRA
MRA
  • 7,607 posts
Posted 12 October 2011 - 11:25 AM
The HIF38 will give you an increase but if your plans are to put a big valve head (Either a cooper or 1275) then you should go for a HIF44 instead really.
Or even better than both of these get Twin HS2's modified as per Vizard.
Jesus
The OP's engine is a 998 and as such will not work as efficiently with a HIF44 (44mm = 1.75" approx) as it would with a HIF38 (38mm = 1.5")
