Hi, Help me please...... I am in the process of building a 1330 engine with a modified head, I have had the head worked on by Rob Walker he has put new guides,valve seats re cut the valves and generaly made it all nice and new, I have purchased some new dual valve springs from mini spares ( C-AEA526) and once fitted I have noticed that one valve in particular ( inlet on no: 3 Cylinder) is a lot lower than the others?? Now in the fitting instructions it says it is advantageous to correct and match the valve spring heights (measured from the spring seat in the head to the underside of the spring retainer cap)
A. How do you measure this???
B. the shims you can adjust the heights with will adjust the spring tension not the valve heights?
Or have I got a brain fade on this???
Now most of the spring and valve heights will be slightly out is it just the valve springs I have to worry about or am I looking to set the valve heights out too???
Please help if you can cheers peeps Andy.
DSC_0110 (2).jpg 197.94K
34 downloads
