I have recently fitted a metro 1275 (I'm very new to this so bare with me) to my mini. I recently posted about a lip around the output from the head to the heater valve.
http://www.theminifo...l=&fromsearch=1
Well after searching around I now realise that the hole has been drilled as the metro did not have a heater output at that point. The heater valve was clogged and thus no water was passing when open or closed. I have freed up the valve and cleaned it with citric acid.
I understand the metro did not have a bypass hose and the common thing to do is to
"Drill 1 or more holes in the thermostat"
I have a number of questions I hope there are answers to:
1) I have no idea what radiator I have, here is a picture of the inside - I assume it is 3 core as there are 3 rows or channels inside?
2) Is the radiator I have suitable for the 1275 with a piper fast road cam and a mildly ported head?
3) If I was to drill hole(s) in the themostat to allow the heater to be shut off in the absence of the bypass hose how many should I drill? There are opinions ranging from drilling many small to one large hole
Minispares
http://www.minispare...ty=pb&pid=35425
It is possible to run thermostats with the troublesome by pass hose blanked off by drilling 4-6 holes 1/8" in size around the priphery of the thermostat.
TheMiniForum
http://www.theminifo...showtopic=94584 A range of answers
Personally I think 'less' larger holes are better as there would be less issues with clogging?
4) If I were to drill the holes, where should I drill them?
Just checking really, they can really only go aound the ourside disc as you can't really drill anywhere else.
5) As an alternative to drilling holes or having to leave my heater valve open all the time what are people's thoughts on using the sandwich plate as used in the metro
http://www.minispare...ty=pb&pid=33405
I have a minispares ally inlet which I could then run the water out of the sandwich plate though the inlet manifold and then T piece it to the outlet from the heater.
http://www.minispare...id=35083&title=
This would allow me to retain my heater on / off and the engine will heat us as usual. What are people's thoughts on this route?
Thanks in advance
Charlie
