Oil Gallery Blocked
18 replies to this topic
#16 hepple
hepple
  • 312 posts
Posted 23 October 2011 - 03:45 PM
Air Filter, debris ruining the bores.
depends how bad the rings are, sometimes oil will always be in the cylinder causing a good reading.
ahh, I haven't no.
I did do a compression test with putting a bit of oil in the cylinder and it didn't really rise much at all (around 5psi)
James
#17 hepple
hepple
  • 312 posts
Posted 23 October 2011 - 03:46 PM
What do you mean by loose filter linkage?
I wondered that also. Perhaps liirge meant "leakage" not linkage?
My take is the same as those above who suggested bad rings. A leak down test will identify all sorts of problems and do a better job of it than a compression test alone.
I will find a garage to do a leak down test for me and then see what that says :)
James
#18 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 23 October 2011 - 07:16 PM
Absolutely! Sorry for that!!
#19 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 23 October 2011 - 10:01 PM
you can have knackered rings and decent compression, if oil rings let oil past the oil can help to seal the compression rings when you test it.
