Mig Welding Problems
Posted 29 October 2011 - 01:55 PM
Posted 29 October 2011 - 02:16 PM
Posted 29 October 2011 - 02:17 PM
about seeing where you're going, you want to be pointing about 40 degrees towards the direction on travel, get down close to the weld. You will get to feel the weld, the sounds etc too.
Just keep practising, then pop up back here again and post some pictures
Posted 29 October 2011 - 02:19 PM
Posted 29 October 2011 - 02:21 PM
but as I say, practise and pictures
Posted 29 October 2011 - 02:24 PM
Posted 29 October 2011 - 03:02 PM
Posted 29 October 2011 - 03:22 PM
i have just tried again using the old mask i had and i can see perfectly! i think the new mask is either too dark (cant see anything) or too light (welder arc too bright to see) and i cant find an in between!! with adjusting cheap mask, i have faired better with small pulse welds rather than longer bursts, the only other thing is my welds are tall and thin even when trying to move side to side a little? my welder is a clark 130te turbo and it has a pub size co2 bottle which says for food use on it? this is how i bought it, would a argon mix work better ? and i suppose practice is the answer
Posted 29 October 2011 - 03:29 PM
Direction of travel :thubsup:
Posted 29 October 2011 - 04:29 PM
Paul.
Posted 29 October 2011 - 04:56 PM
Posted 29 October 2011 - 05:06 PM
Posted 29 October 2011 - 05:53 PM
I went back to a conventional mask, which works just fine
David
