Removing Dashboard
Posted 05 February 2006 - 01:06 PM
1981 998 mini: How do you get the topmost section of the dashboard off? It's the padded bit immediately below the screen I'm trying to remove. I've undone all the nuts I can find, and it's very loose, but just won't lift out. Does the screen have to come out first?
Posted 05 February 2006 - 01:22 PM
Posted 05 February 2006 - 05:54 PM
Posted 05 February 2006 - 05:55 PM
on mine there were three bolts (left, right and centre). undo them all and wiggle the rail off
Posted 05 February 2006 - 06:04 PM
Posted 05 February 2006 - 07:22 PM
there is a bit of a trick to this .....
its not really the up motion you want to be twisting it out towards the rear of the mini. you will find it comes out quite easy with the screen in .
eddie
Posted 05 February 2006 - 07:48 PM
Posted 05 February 2006 - 08:05 PM
Posted 05 February 2006 - 08:06 PM
Paula
Posted 05 February 2006 - 08:10 PM
Posted 05 February 2006 - 08:29 PM
it also depends on how old the mini is because the earlyer cars that had the top rail fitted, there were just 2 extra holes derilled in each side. whereas the later ones had larger holes and a slot cut away in the bottom so you can get a socket in it
Almost. The very early Mini Clubman had the upper rail held by 4 studs with nuts along the top, all later cars and all non-Clubman cars with a top rail have two outer studs with nuts and a center one using a clamp though the ashtray hole in the bulkhead, which has always been there.
Posted 07 February 2006 - 05:49 PM
The trick was to use a screwdriver to lever each bolt out of its hole. It would then jump forward and not go back down the hole while I levered the next one.
As I'd feared, it's all rusty, so it look like there's a screen leak (
