Clutch Slave Cylinder Bolts
Posted 05 November 2011 - 05:41 PM
Posted 05 November 2011 - 05:47 PM
Posted 05 November 2011 - 06:07 PM
Posted 05 November 2011 - 06:44 PM
Non verto is 3/8 UNC x 1 1/4"
verto is 3/8 UNC x 1"
If you were to use the 1 1/4" in the verto bracket, the bolt (screw) could be too long, and poke into the flywheel teeth, and lock the engine.
Posted 05 November 2011 - 07:03 PM
Posted 05 November 2011 - 09:06 PM
Carefull; Verto and non-verto are the same thread, but different lengths.
Been there, done that!!!!
Posted 06 November 2011 - 07:54 AM
Yep, can certainly be a head scratcher...
Posted 06 November 2011 - 01:41 PM
As a basic rule, anything going into aluminum is UNC (coarse thread). If UNF (fine thread) is used then it has a greater possibility of stripping the aluminum.
UNF Fine threads are generally used whenever a nut is used as they give finer control when applying torque.
There are many exceptions e.g. manifold studs which are UNC into the head and UNF to the nuts even though the head is steel and not ally.
Charlie
Posted 06 November 2011 - 03:28 PM
1) 3/8" UNC x 1.25" long for pre verto slave cylinder to transfer housing
2) 3/8" UNC x 1" long for verto slave cylinder BRACKET to transfer housing
3) 3/8" UNF x 1" long for verto slave cylinder to BRACKET.
4) 1/4" UNF x 1.5" long Verto bracket support bolt to clutch cover or WOK
The reasoin UNC isi used in the head is because CAST IRON is a "course" grain material the same as aluminium.
Although you will find that UNC & UNF are both used in to the head casting, poor design ??
And fo rth erecord the manifold studs are UNF at both ends.
Posted 07 November 2011 - 05:51 AM
http://item.mobilewe...nid=23868513119
But there is no hard and fast rule
Charlie
Posted 07 November 2011 - 03:53 PM
I'm very sure the manifold studs are unc into the block and unf the other end
Charlie
All inlet/exhaust manifold studs on all classic Minis are 5/16" UNF into the head. I always replace these with 5/16" UNF x 1.25" long bolts so that the head gasket can be changed without undoing the exhaust pipe from the manifold.
Edited by Cooperman, 07 November 2011 - 03:53 PM.
Posted 07 November 2011 - 05:31 PM
Great idea!
Posted 13 September 2016 - 12:13 PM
could any one help?
I'm looking for the bolt or bolt size of the long bolt at the front of the brake which goes through the sleeve and into the bell housing?
cheers,
Jordan
Posted 13 September 2016 - 12:21 PM
could any one help?
cheers,
Jordan
why have you used the work brake?
verto or earlier?
number 31 by any chance
http://www.minispare...ing.aspx?1~3~31
Posted 13 September 2016 - 12:40 PM
could any one help?
cheers,
Jordan
verto or earlier?
sorry i misspelled i wanted to put bracket but my phone changed it, and its veto, I don't think so, the bolt goes on the bracket of the clutch slave cylinder and through a sleeve i think its about an inch long.
