Clutch Slave Cylinder Bolts
22 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 13 September 2016 - 03:28 PM
That one has been discussed above and is 1/4" UNF by 1.5" long.
As for manifold studs, my Minis all had UNF both ends which was somewhat surprising to me, but that is how they were, from about 1961 848cc to 1984 A+. I do hear that many are UNC at the head end but have never seen one yet. Very odd! Maybe the factory ran out of UNC taps on at least 3 occasions?
#17 Shaggy33
Shaggy33
  • 311 posts
Posted 13 September 2016 - 04:03 PM
on the same vein, why are there two threaded bolt holes with captive nuts on the slave cylinder itself? When I mounted mine I use the holes on the plate to bolt to clutch housing.
Am I doing it correctly.
#18 tiger99
tiger99
  • 8,584 posts
Posted 14 September 2016 - 12:18 AM
I don't understand. There are two captive nuts on the plate, surely? The cylinder just has two plain holes.
#19 nicklouse
  • 18,742 posts
Posted 14 September 2016 - 09:58 AM
 you have the wrong part then.
#20 Shaggy33
Shaggy33
  • 311 posts
Posted 14 September 2016 - 11:22 AM
I have no bolts through the cylinder as you can see. All I have is two bolts on the other end of angled plate holding it clutch bell housing....
Either cylinder has seized in place on the plate or it's being held there by invisible powers....
#21 tiger99
tiger99
  • 8,584 posts
Posted 15 September 2016 - 11:37 AM
Well, that is just plain wrong as you can see the captive nuts on the back of the plate where the bolts should go. Someone has possibly broken both bolts in their holes and perhaps used something like superglue to try to fix the cylinder in place.
You should take it apart and fix it with new bolts. You may have to drill out and rethread the plate or get a new one.
#22 nicklouse
  • 18,742 posts
Posted 18 September 2016 - 08:18 PM
As above you need bolts.
You are also missing the spacer and bolt to hold the plate to the caseing. See the exploded view
http://www.minispare...e.aspx?2~13~121
#23 tiger99
tiger99
  • 8,584 posts
Posted 18 September 2016 - 08:33 PM
I am amazed that it has not come loose!The spacer is quite important. I am still pondering the mysterious invisible bolts...
