I have installed a Lumenition system and Coil to my ballasted system.
I have a Black and White wire, well two actually that pop out of the loom near the coil and dizzy.
Both of these were connected to the Negative side of the coil. One end goes to the tachometer, the other end I dont know.
I have now a 3rd black wire that comes out of the side of the dizzy thats the negative feed from the small Lumenition module thats been installed within the dizzy. There is also a red one that is wired to switched live.
My question is do both black and white wires from the loom AND the new black wire from the Lumenition module attach to the Negative side of the coil?
Cheers all!
Ignition Coil Black And White Wires
maccers
, Nov 09 2011 12:44 PM
1 reply to this topic
Posted 09 November 2011 - 12:44 PM
Posted 09 November 2011 - 12:51 PM
On a standard loom you normally have a black/white wire that comes out the loom near the dizzy with a female spade connection, The standard dizzy and a lot of aftermarket electronic conversions have a black wire with a female spade, Just plug the dizzy wire into the loom wire.
The other black/white again with female spade connects to the coil negative.
Edited by lrostoke, 09 November 2011 - 12:52 PM.
