1275cc Head on a 998cc
Posted 05 February 2006 - 06:56 PM
They bolt on a 1275 head and there is no mention of pocketing the block
So will a 1275 head fit straight on? Mini World says otherwise
Mini mag says there will be a 0.042 inch clearence with gasket
Rocker Ratio of 1.22, Is that a standard Rocker?
Very Confusing for me :saywhat:
:wales:
Posted 05 February 2006 - 07:00 PM
If you are thinking of doing it yourself then do a trial run first, fitting the head without the gasket then turn the engine by hand and see if you have any issues.
Posted 05 February 2006 - 07:17 PM
Edited by Dan, 05 February 2006 - 07:18 PM.
Posted 05 February 2006 - 07:22 PM
So if you say this is no DIY job for the begineer, Can you suggest a cheap engine builder?
:wales:
Posted 06 February 2006 - 01:42 PM
Posted 06 February 2006 - 02:12 PM
Posted 06 February 2006 - 02:46 PM
Edited by Dan, 06 February 2006 - 02:46 PM.
Posted 06 February 2006 - 02:49 PM
Simon at Morspeed is good and while he's not cheap he won't rip you off.
Have you got some contact details? Where is he located?
Posted 06 February 2006 - 07:47 PM
Morspeed Performance Tuning, near Leicester.
Posted 06 February 2006 - 08:34 PM
Rebuild it yourself, if you get stuck in sure iceman/ woody and the rest of the lads down at Peblic will help you if ya get stuck!Anybody got an idea of how much that 998 rebuild would cost?(The one in the Mini Mag)
Posted 06 February 2006 - 08:56 PM
at the time i did not want to raise my insurance policy costs with a larger engine & decided to carry out this mod after my mate gave me the idea....
i got hold of 2 old 1275 valves , one inlet & one exhaust...
i then fitted the new head onto my 998 block & painted the valve faces on the head (i did not tighten the head down) , i then fitted the pushrods & rockers & rotated the engine 2 turns..
note that i did not fit a head gasket so that the valves actually touched the block face & left a nice paint outline onto it...
once the head was removed i managed to use the old valves in a drill & a tub of valve grinding paste to cut out pockets on the block face.
it took me all day to do this though as i was carfull as not to slip !
anyway , after all that i fitted a 1275 headgasket & built it all up & fitted a 1.75 su carb off of a mg metro.
the result was fairly good , not much more in acceleration power but sheds load more torque , especially low down where as before it was always flat & needed a lower gear change....
i do have pics of this job i did , these are at my parents house ... i will dig them out next time im there & post them up here.
be warned that unless you pocket the block , you will end up with bent valves !
mark
