Engine Sounds Like Is Gonna Blow Please Help Me
29 replies to this topic
#16 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 07:30 AM
Just had spark plugs out first 2 sooty with chocolate coloured tip 3 all sooty and 4 was white i had ran it on slight choke and turned choke off and ran for another 20 secs after before checking here a pic of cylinder 4 plug
Danny
#17 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 08:14 AM
Just been out to get video is only making the noise now under load might sound wierd but could it be clutch as the bitting point is quite high always has been
Thanks Danny
http://static.photob...23-08-04-13.mp4
Edited by mini danny, 23 November 2011 - 08:16 AM.
#18 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 23 November 2011 - 10:42 AM
Has the timing slipped and what you describe is actually pinking? Have you examined the distributor since the initial event?
#19 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 10:50 AM
Nah i haven't yet i rang mmc and they said they had this loads of times its the head gaskets apparently so gonna strip it down and check if no visable damage will change gaskets and refit and see what happens
Danny
#20 Frisco
Frisco
  • 414 posts
Posted 23 November 2011 - 11:15 AM
That sounds very bottom end mate.
#21 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 12:13 PM
Ya i was thinking that but the noise from the top of the engine not the bottom and woundnt explain the loss of power if it was bottom end if i put my foot down it just won't pull
#22 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 23 November 2011 - 12:21 PM
When a head gasket goes between cylinders it can give just that sort of noise as the "explosion" from one cylinder can "blow" across the broken gasket section and hit the top of the piston coming up the cylinder. Wouls aso account for the sudden loss of power/performance.
The sound given off by this happening sounds like severe pinking/detonation. If the noise is deffo coming from the top of the engine it could be piston problems.
However, by the same token, it could be big end problems although these tend to come on gradually with lowering oil pressure and a "harsh" feeling engine. As others have said, time to whip off the head and see whats going on.
Post up some piccies of what you find.
Cheers,
Steve.
#23 Frisco
Frisco
  • 414 posts
Posted 23 November 2011 - 02:08 PM
Its time to stop running the engine anyway, if its a big end gone then it could easily throw a rod and destroy the engine and box.
Taking the head off is easy so start with that anyway
#24 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 03:12 PM
ya im not running engine stopped running it after the video strip down tomorrow and have a look im hoping its the gasket ill post piccys up tomorrow of everythink danny
EDIT: would you say ild be ok to run a conpresstion test today ?????
danny
Edited by mini danny, 23 November 2011 - 03:26 PM.
#25 Frisco
Frisco
  • 414 posts
Posted 23 November 2011 - 05:30 PM
It should be fine since there is no load on it but it does depend on how long its been happening
#26 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 23 November 2011 - 05:33 PM
I decided not to and have striped it down in dark so decided probz not best idea to actually remove the head in the dark so can wait till tomorrow will post pics of my finds
Danny
#27 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 24 November 2011 - 03:22 PM
Changed head gasket today really please with my self got power back and noise has gone
And checked all valves and all good
thanks everyone for your help :)
#28 Sam Walters
Sam Walters
  • 2,765 posts
Posted 30 November 2011 - 01:19 AM
Between 2 and 3? That was not the noise i was expecting at all! In fact i know what that noise sounds like on a 998! I also know what it sounds like on a full race 1293. Not a nice noise at all!
#29 se_juggles
se_juggles
  • 1,043 posts
Posted 30 November 2011 - 01:27 AM
id just go caveman on its ass and hit it... works with the tv!
#30 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 30 November 2011 - 07:36 AM
Haha go caveman lol and 3 and 4 where fine still got gasket will post more pics up later
