16v head
Posted 07 February 2006 - 04:42 PM
we believe that with valve pockets in the block face and piston crowns it is very simple to put together, you would also need to dry deck the block, so this only leaves you woth the firing rings to worry about in the head gasket.
ferriday engineering said they would make us a head gasket to fit by they way, very helpfull people.
however we did start to wonder if it was going to be worth all the expense as we wernt sure if the mild cams in the head were going to be any good to us.
the block would also need ree-drilling and tapping to take the studs in the positions that they are already in, in the nicra head.
the head itself uses a timing chain, as per A series, however the head must be turned 180 degrees to have the chain at the right end of the block. it then also turns in the right dirrection and the inlet now faces forwars ready for webbers,
just thought i would pass this on as i would love someone to continue where we shelved the project.
jez
Posted 07 February 2006 - 05:09 PM
you should get together and talk over any problems :wink:
Posted 07 February 2006 - 07:48 PM
just to see how close they are/etc
Posted 07 February 2006 - 08:38 PM
Posted 08 February 2006 - 03:38 PM
i am also curious as to which bike head it is you are using, a relative works high up in a local bike shop called "streetbike" dunno if you heard of it? i may be able to source some parts, or information should you require it?
the valve in the head on the micra were of sufficint size for the spec of engine we were going to mate it all to, as for flowing, there a allot of people out there doing fantastic head work on this casting, its quite popular abroad apparently, racing the little micra.
the head we tried was a 1275 micra, from a W reg car. interestingly the bore and stroke is the same as the 1275 A series, and the 998 micra has the same bore and stroke as the 998 A series, weird eh?
Posted 08 February 2006 - 08:52 PM
I wonder if Nismo did any work on those engines. If they did or do, I bet theres some sweet pistons available for them which should be interchangable with the A series.
Posted 08 February 2006 - 09:54 PM
Hi, thanks for that! I am using the BMW K1100 head, like sprocket and many others. I will pick up a micra head next time I visit a yard and have a look, especially interested in the 998 one as I have a bit of a thing with 998's.i will endevour to get some pics on here, i really aint good with computers, but i'll get my mate to help me out with it.
Thanks for the offer of help with parts, I will keep you in mind if I need anything
If you want to email me the pics, I will put them up here for all to see if that helps at all?
Oldskool, nismo, mmmmm....
Posted 10 February 2006 - 04:37 PM
as soon as i can get the pics done i'll send them to you.
i have to agree with the liking of the small bore block, i'm keen on the extra material around the bores, something you dont have allot of with the popular 1380 big boys, particularly between number 2 and 3 cylinders.
its small bore all the way for me, lightened and balanced with a quality 12g940 head and thats a great little screamer, lovley!
Posted 18 October 2007 - 11:22 AM
Datsun/Nissan was a licensee of Austin Motor Company technology. They build there own version of the A-Series engine.
See http://en.wikipedia....Nissan_A_engine
Would this 8 port (!) head fit a BMC engine?
Posted 05 February 2009 - 11:02 AM
any info would be wicked! cheers!
Posted 05 February 2009 - 01:24 PM
Get a head gasket for each and compare!just read this after coming back from the scrappy, those nissan engines are twin cam! (well some are) how feasable is it to put this head on an a series block? 998??
I would imagine that this conversion would already have been done and be a lot more popular if it was that easy/worth it.
