I'm going to have a go at DIY boot board for my Dads Mini and mine!!
I've got the templates, I've got the measurements.. all I need is the size of the MDF sheet if I was to keep them all on one piece rather than buy loads??
Anyone know this. Working off MiniFinity.com template.
Jack
Boot Boards
BerkshireMini
, Feb 08 2006 03:26 PM
6 replies to this topic
Posted 08 February 2006 - 03:26 PM
Posted 08 February 2006 - 04:06 PM
As it uses a few different sizes and thicknes boards, you are going to end up with a couple boards no matter what you do..
Still worth it in the end though, makes a huge difference to the look of the car
Get 8 ft x 4ft boards and you will have enough to make a few sets, then just shove a set on ebay and you will get your money back..
Posted 08 February 2006 - 05:00 PM
Thanks, a great help!
Posted 08 February 2006 - 05:39 PM
to make it nice and sturdy i would use 12mm for the base and back bit and 9mm for the sides and 6mm for the tank cover maybe thinner so it is nice and flexible.
look at the link for what is normally used though.
http://www.miniproje...t_board_kit.htm
Posted 08 February 2006 - 06:30 PM
Posted 08 February 2006 - 06:42 PM
Hey Pepe
Have you covered your boards yet?
Posted 08 February 2006 - 10:47 PM
You done the link wrongcheck this link.... these are the boards i've been doin.
http://www.theminifo...showtopic=19189
pepe
Meant to put the address first then the name of the link :smartass:
don't worry tho, I got the Link ta!
