Steam From Rad Even With New Cap.
15 replies to this topic
#1 Brookesy
Brookesy
  • 507 posts
Posted 07 December 2011 - 10:44 PM
Hi all
Mini is a 1989 mini 30.
So this weeks problem is this. Last week Radiator started leaking water through the radiator cap. Spurting onto the underside of the boot/inside engine bay e.t.c. I ordered a new 15lb rad cap from minispares and kept the coolant level topped up till it arrived today. Fitted the new cap and thought all was well.
However although it has stopped leaking coolant it is still leaking steam which is condensing on the bonnet still and still making a mess! Engine temp is ok but can see the steam when stopped at lights e.t.c.
All the hoses seem ok with no other leaks. Maybe the radiator fitting that the cap fits too is out of shape?
Any advice would be great. Thanks Mike
#2 Cooperman
  • 23,324 posts
Posted 07 December 2011 - 10:48 PM
Sounds like a damaged cap seat, but that's a bit unusual. Is it overfull with coolant? If it is, then it will push coolant out as it warms until it reaches a 'full when hot' level.
#3 Brookesy
Brookesy
  • 507 posts
Posted 07 December 2011 - 10:52 PM
Well at the moment it is sat flush with the metal 'filament' inside the radiator. Which i think may even be a bit under?
#4 Cooperman
  • 23,324 posts
Posted 07 December 2011 - 10:57 PM
It shouldn't steam then once it's hot.
#5 zef
zef
  • 223 posts
Posted 08 December 2011 - 12:00 AM
Coolant system blockage or sounds like the coolant system might be getting pressurised. Could be a head gasket.
#6 Brookesy
Brookesy
  • 507 posts
Posted 08 December 2011 - 12:46 AM
So bleed the rad first if still not fixed then check head gasket? well other way round..
#7 icklemini
icklemini
  • 2,982 posts
Posted 08 December 2011 - 10:18 PM
seen a few of these recently:
- Water level should be flush with the filament... the 15lb cap shouldnt be venting..., seen a radiator last week with a tiny crack in it...
Before going too crazy and taking everything apart - get the cooling system pressure tested to see if the system is holding pressure, and if not: trace the leak...
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 December 2011 - 10:22 PM
You sure the cap has the right stem length to seal down inside the radiator ?
#9 zef
zef
  • 223 posts
Posted 08 December 2011 - 10:23 PM
I'd bleed the system first, yes.
Remove the cap, turn the heater to hot and top up the system while running the engine (watch your fingers). Leave the cap off until the system gets up to temp, the thermostat should then be open. That should shift any air.
#10 Brookesy
Brookesy
  • 507 posts
Posted 08 December 2011 - 10:34 PM
Cheers for the advice. Will try and shift any air there may be and if it still vents on the way to work ill ge tthe pressure tested :)
Thankyou once again. blooming cars fix one and out pops another!
#11 Brookesy
Brookesy
  • 507 posts
Posted 09 December 2011 - 11:04 AM
It seems a touch short butits the same as the old one and the right one for the year of the car. Old one worked fine till itt started spurting:(
#12 adam_93rio
adam_93rio
  • 3,271 posts
Posted 09 December 2011 - 12:06 PM
Are you sure the radiator hasnt been changed at some point. The stem shouldn't be short
#13 Brookesy
Brookesy
  • 507 posts
Posted 09 December 2011 - 11:36 PM
So ive searched throughly and there is definatly no leaks. After doing a bit of research im thinking maybe a head gasket problem. Going to check oil tommorow for water as the amount im loosing from the rad cant just be from steam..:/
#14 Brookesy
Brookesy
  • 507 posts
Posted 10 December 2011 - 09:04 AM
Oil is also fine. Nice and dark. Time to visit le garage I suppose...
#15 Ethel
  • 26,057 posts
Posted 10 December 2011 - 09:36 AM
Squeeze the top hose to see if it pressurises before it warms up. It's a fair indicator of a duffed headgasket. Sometimes you see mist in the radiator header too.
