Is A Centre Main Strap Really Necessary?
#16
Posted 17 December 2011 - 12:40 PM
#17
Posted 17 December 2011 - 05:20 PM
If I was going to start messsing then I'd go for a 4 bolt main,
One thing I would recomend though, is a set of billet main bearing dowels from swiftune, 15 quid for the 6, and the fit really snug, and are thicker than the std ones, well worth it IMO.
#18
Posted 03 January 2012 - 02:45 PM
So I got bought a Main strap for my engine build im doing at the moment for chrimbo.
However I read somewhere about having them machined before fitting.
Is this true or can I just wack it on to the correct torque staight away?
#19
Posted 03 January 2012 - 02:54 PM
you have to machine the mini's main bearing cap flat otherwise the strap wouldnt fit. the cap has two flats where the bolt holes are and a raised section in the middle. they machine off this middle section and you get a nice flat surface you can bolt the strap on to.
#20
Posted 03 January 2012 - 03:05 PM
You could list the special parts which are not necessary for road cars but which owners buy due to 'sales hype'. Typically these include 4-pot callipers, coil spring suspension, vented discs, beam rear suspension, and so on. Whilst these may be thought of as 'nice bits', for a road Mini they really are not vital. But the parts suppliers do make a lot of profit from selling this stuff so they will infer that all Mini owners desparately need it all! Cynical, me?
#21
Posted 03 January 2012 - 04:19 PM
i got this one, really well made and cheap (ish)
Hhhmmm I see thanks for that, not quite as sinmple as I thought then.
Is this something they can do with the gearbox off but the crank in?
#22
Posted 03 January 2012 - 04:36 PM
Yes, just remove the centre main cap, take it to the machine shop and have it milled flat across the bottom face. Then re-fit it using gthe strap and the 2 new bolts supplied with the strap. You can't fit the 4-bolt strap with the crank installed as that involves drilling and tapping into the bottom of the block.
#23
Posted 03 January 2012 - 08:29 PM
Edited by AndyMiniMad., 03 January 2012 - 08:29 PM.
#24
Posted 03 January 2012 - 08:40 PM
As for steel caps, very expensive, not only the initial cost of buying the caps, but then line boring of the block and caps true.
#25
Posted 05 January 2012 - 11:54 AM
