10X6 Wheel Arch Help? Cutting/fitting Etc..
27 replies to this topic
#16 drumindan
drumindan
  • 82 posts
  • Local Club: Bmc
Posted 17 December 2011 - 06:34 PM
Ye i guess the best thing to do is wait and see once its together got all front in bits atm made it bumperless gotta do back but not looking forwards to that haha should be good when done fingers crossed
#17 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 04 July 2012 - 11:57 PM
i am just awaiting the arrival of my 7.5" 4 pot cooper brake kit so that i can fit either 10x6" deepdish minilights, stramags or slotmags and i want to know will wood and pickett arched fit fine or do i need to go bigger and more importantly do i need to cut away any of the arches and how do i go about that and fit arches on once cut (if neccesary?? :-)
well just so you know (you may have sorted it now but anyway...lol) i have 10x6 deepdish mambas (huge offset) they rub the arches a lot and its about the same height as the chap with the blue mini photo'd i cant go anywhere near full lock otherwise ill bend my hole wing -_-
i cannot cut the wheel arch because the arches are mounted on the lip, and if i cut it theres no lip.
so i have either got to change wheels (last resort) or take of the arches lower it and see where im at which changing the arches
just so you know!
#18 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 05 July 2012 - 10:06 AM
whether you need to cut wing front panel area also depends on ride height if its lowered then it will most lightly need triming
#19 GuamMini
GuamMini
  • 54 posts
  • Local Club: Guam Classics
Posted 17 November 2015 - 10:46 AM
Without researching i bought a 10x6 set of minilites with 165 falkens. I was trying to install them on my 1973 mini clubman 1275 gt. I found out that the wheel rubs on the caliper. When i treid to install it on my 1970 mini k with the 7.5 disk conversion. It still rubs but very very small a washer would clear it. What can i do to clear the calipers on the clubman?
#20 GuamMini
GuamMini
  • 54 posts
Posted 17 November 2015 - 10:47 AM
#21 nicklouse
  • 18,682 posts
Posted 17 November 2015 - 11:33 AM
normally the wheels should be a straight fit on a car with 10" wheels as standard.
what was your car built as as standard?
likewise they should fit on any 7.5" brake set up for 10" wheels.
more precise info needed. calipers? where is the rub?
and what is the ET on the wheels? are they for a Mini fit or?
pics are great.
#22 GuamMini
GuamMini
  • 54 posts
Posted 18 November 2015 - 12:55 AM
Both cars have a 7.5" disk setup. The only difference one is after market and one is original. they rub where the bleeder screw is. I bought this wheels from Minisport and they are supposed to be for a Mini. is it safe to use 19mm spacers in the front? The center caps are also loose they sink into the hub.
Edited by GuamMini, 18 November 2015 - 01:16 AM.
#23 nicklouse
  • 18,682 posts
Posted 18 November 2015 - 09:02 AM
very ODD.
it is catching in the wheel and not a balance weight?
I would be contacting the seller and sking questions.
#24 spiguy
spiguy
  • 1,537 posts
Posted 19 November 2015 - 10:35 PM
For those with 10x6 wheels catching the arches, have you checked the situation at the teardrop mount? You may need / get away with spacers between the back of the teardrop mount and the subframe. On my car, when I took out the bolt, there was a few mm gap, which when the bolt was tightened was being squashed up. I inserted large thick washers between the mount and the subframe to take up the gap. I didn't actually need this to correct any rubbing, on my car with 10x6 GB's there is no rubbing (it's close though!) but spacers / shims in this area can increase the clearance to the front edge of the arch in some cases. They were fitted at the factory on some cars to correct rubbing.
Minispares sell packing spacers for this : http://www.minispare...sic/2A4292.aspx
Just a thought.
Edited by spiguy, 19 November 2015 - 10:36 PM.
#25 James_eaton_thewholething
  • 1,063 posts
Posted 19 November 2015 - 10:56 PM
Just a thought.
It would still all come down to the offset of the wheel. I have 10x6 wellers and without cutting the arches it would have never gone round a corner. With this in mind when I replaced the wings and front panel I had to cut it out to the sports pack arch size in order to clear
#26 GuamMini
GuamMini
  • 54 posts
Posted 19 November 2015 - 11:37 PM
My problem is the wheel rubs here, the outside lip
#27 nicklouse
  • 18,682 posts
Posted 19 November 2015 - 11:45 PM
Like I said I would be asking the sellers.
You may just have some out of spec wheels. But I would be finding out what has actually happened.
#28 GuamMini
GuamMini
  • 54 posts
Posted 19 November 2015 - 11:47 PM
I created a separate thread because I did not realize this was for cutting the fender etc. Sorry
