Bmw Twin Kam Conversion
5 replies to this topic
#1 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 19 December 2011 - 05:28 PM
Have decided to sell up the bits collected for the BMW conversion I had panned.
Parts are based in Nottingham,2 Miles from J26
Pretty much a comprehensive kit, all parts are Specialist Components unless otherwise stated
  • SC ‘K’ Conversion Kit, comprising of:
  • 1x SC Top Plate and Seals
  • 1x SC Bottom Cover and Seals
  • 2x SC Alloy Vernier Top Pulleys
  • 2x SC Cam Pulley Adapters
  • 1x SC Lower Pulley Kit (Jackshaft and Crank)
  • 1x Extended Crank Bolt
  • 1 x Bottom Plate Bolt Kit
  • 2 x Woodruff Keys
  • 2 x Crankshaft Pulley Shims
  • 2 x Camshaft Pulley Bolts & Washers
  • 1 x SC Block Spacer
  • 1x Cam Belt and Tensioner Kit
  • 1x SC Block Drilling Template
  • 4x SC Billet Ram Pipes
Other parts
  • SC Typhoon ECU, pre-mapped.
  • SC Crank Trigger Kit including sensor
  • SC Bespoke ‘K’ Wiring Loom and Air Temp Sensor
  • SC Billet Ancillaries Kit
  • SC Crank Trigger Kit with Crank Position Sensor
  • SC K’ T304 Stainless Steel Exhaust Manifold.
  • SC Billet Remote Thermostat.
  • A+ block, with galleries filled, and re-drilled, Cyclinder head stud holes, filled and moved to correct position.
  • Build Manual
  • Camshaft, with lobes removed.
  • BMW K series 16v head converted and skimmed to fit A series Block. this comes with correct throttle bodies and fuel rail.
  • I will also throw in a full MPI fueling set up, comprising of MPI tank and full set of MPI fuel lines to fit a mini.
You will need a crank, con rods, (I can provide standard items) Pistons, gaskets and other bits and bobs.
I also have a Guessworks fully rebuilt gearbox with straight cut drops and a cross pin diff, and a racing (orange) clutch set up. Don't really want to sell this but would do all the above for £3,000.
The kit has been assembled "dry" but never started.
£2,300 or neasest offer or £3,000 with gearbox and clutch set-up
nicholasverity@hotmail.com
Edited by clubman katie B.F, 19 December 2011 - 05:33 PM.
#2 rickmercs
rickmercs
    Just On Tickover
  • 9 posts
Posted 19 December 2011 - 06:00 PM
PM.d.
#3 Taylor
Taylor
    Just On Tickover
  • 7 posts
Posted 24 December 2011 - 02:05 PM
Hi their would u be interested in selling any bits separate
#4 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 27 December 2011 - 04:49 PM
Pics please?
#5 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 28 December 2011 - 07:35 PM
I will post pics.
Won't be splitting.
#6 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 29 December 2011 - 03:11 PM
Sold
