so why the different grades for different ambient temperatures specified by car manufactures ?
Headgasket Hasn't Gone But Have The White Mayo In Rocker :\
mini danny
, Dec 21 2011 12:14 PM
22 replies to this topic
#16
Posted 22 December 2011 - 10:48 AM
#17
Posted 22 December 2011 - 10:52 AM
The first number refers to the cold cranking viscosity, colder climates use lower number to ensure the oil is thin and can pump easily from cold.
The higher number refers to the viscosity at 100C (i.e. engine fully warmed up) and is specified to ensure correct protection on the engine.
I think there is some confusion here, the viscosity grade has nothing to do with how long the engine takes to warm up!
#18
Posted 22 December 2011 - 10:55 AM
Because if its colder outside you want the oil to be thinner to start with so your not starving the engine of oil while trying to pump tar around the engine.
The heat will still rise the same but obviously the colder it is to start with the longer it takes to get up to proper temp
#19
Posted 22 December 2011 - 10:59 AM
Agreed!
Also, if you have too thick an oil for the climate, the engine will not even start in the first place as it will turn over too slowly. Any engine has to be doing something like 70-80 revs per minute on cranking to start.
#20
Posted 22 December 2011 - 11:04 AM
so it's more to do with cold runnyness that warm running
thanks
thanks
#21
Posted 22 December 2011 - 11:11 AM
Things are also changing w.r.t the way OEM's specify which oil viscosity grade to use.
These days fuel economy and CO2 emissions are very important, so you will notice they are specifying lower viscosity grades as standard to gain those few extra mpg!!
#22
Posted 22 December 2011 - 11:30 AM
So basically 10w40 and 20w50 have the same heat capacity?
#23
Posted 22 December 2011 - 11:34 AM
It would be virtually the same yes
