High ratio rockers
Posted 11 February 2006 - 02:14 AM
Posted 11 February 2006 - 03:50 AM
Huh? Have I strolled onto Minifinity? (looks at address bar) Nope, It seems to be TMF still...
If this post is still here Saturday Evening, I'll add something.
If it isn't, then I suggest Peter - that you take it to a forum (i can think of three) where engineers who've done a bit, rather than simply 'read a book' reside...
Posted 11 February 2006 - 08:00 AM
Posted 11 February 2006 - 08:14 AM
i do use 1.5 rockers and many of the kits for the late coopers have 1.5 rockes
so lets see the pro's and con's from the people that know
Posted 11 February 2006 - 08:38 AM
The reasons for this have been stated above.
Posted 11 February 2006 - 10:56 AM
Posted 11 February 2006 - 11:57 AM
It is clear now that high ratio rockers are not all bad when used in the right aplication and preferably not on wild cams, which more and more people are fitting to road cars, which is something I will never understand.
Posted 11 February 2006 - 03:03 PM
Also If I understand what's written above then the cam only feels the actual spring load as opposed to the effective spring load. How is this possible when the lever of the rocker is present in the valve train?
And I have just one more question. I think the summary of what you are saying is that increasing the rocker ratio allows greater power to be developed within the engine for zero penalty of increased internal losses. This sounds to me like perpetual motion. Other than increased fuel useage, what exactly is the payoff for increasing the ratio?
Edited by Dan, 11 February 2006 - 05:34 PM.
Posted 11 February 2006 - 06:03 PM
the answer is yes and no, i have used 1.5 roller rockers for the whole 15 years of building mini engines (over 600 engines to my name) and ive seen just about everything.
in my opinion they should not be sold as a 'bolt on' extra. not because there bad, far from it, infact i use them on 90% of my engines, But because without the correct spring & seat pressure they will destroy a cam lobe. And you can bet everyone who buys the 1.5 rockers mail order is doing just that 'bolting them on'
The worst cases ive seen are the john cooper conversions, they use the minisport 1.5 roller rockers and 200lb valve springs, WHY? i only ever use a spring with that rating on a race engine giving .500" lift.
If 1.5 rockers are so bad how come mini miglias use them alongside an STR930 cam giving .485" valve lift? there cams and followers last for years and we no longer see valve guide wear like we used to.
There is so much C**p flying about with 1.5 roller rockers its amazing !!
Infact they are one of the best BHP for your money conversions ive seen, i have done many tests with 1.5 rockers and they do give an increase of 3-8bhp depending on the cam used.
To cut a long story short, i would say to anybody forget 1.5 rockers as a bolt on, but DO get them if you are having an engine built properly by a proffesional who knows what they are doing,
When i say proffesional i mean a company who has cars out there on the race track proving there engines. these are the people who can squeeze every last drop of BHP out of your road engine.
There are too many people who read books/internet or have built 1 or 2 engines and 'think' they know whats best, they dont.
Posted 11 February 2006 - 06:23 PM
To the average Joe on the street, they are sold as a bolt on performance mod, without regard to the destructive influence which they will have on valve train wear..and here we are talking about the 1.5's in general..
1.3's are not far off std ratio ( being 1.25 ) so the benefits of less sideward load on the valve stem because of the roller, probably outweigh the issues associated with the extra .05 ratio on the lift.
Posted 11 February 2006 - 08:38 PM
so my next question is what lb springs should be fitted with these rockers ?
Posted 11 February 2006 - 09:12 PM
Posted 12 February 2006 - 01:02 AM
I ask because i have noticed that when dealing with uprated cylinder heads or anything that effects the valve train you see companies almost bragging about spring strength is this just another case of bigger is not always better?
hope that made sense :lol
Posted 13 February 2006 - 01:24 PM
Posted 13 February 2006 - 02:05 PM
