Injection Or Carb?
Posted 23 December 2011 - 01:32 AM
Mini SPI
Or
Mini Carb'd
For
1. Reliabilty
2.Maintenence
3.Power/Modifcations
(I want true opinions and arguements.)
Posted 23 December 2011 - 01:54 AM
Posted 23 December 2011 - 08:27 AM
yes i could squeze a bit more BHP and MPG out of a fully mapped injection system but i don't have that sort of money and when it goes wrong don't have the knowledge to fix it my self
in the cornish mini club we have both carb , SPI and MPI coopers
my car has beeten them all for power on a rolling road with similar mods at a club rolling road day, i can beet the SPI for MPG and match the MPI when we convoy to shows
for a simple, cheap, fix able system i'm sticking to my carb
Posted 23 December 2011 - 08:48 AM
Posted 23 December 2011 - 09:08 AM
Posted 23 December 2011 - 11:27 AM
Posted 23 December 2011 - 11:48 AM
1. Over the three years i have a had my spi it has been a daily driver, ive never had any major problems and have just done the routine maintenence to keep it running, its never missed a beat! My friend with a carb has had his a year and has several problems, once or twice it has been down to the carbs, most of the time it is the normal problems you could have on any mini.
2. I have only had to do the usual maintenence, spark plugs, oil filter etc. So from that im saying spi is better.... just more expensive (sometimes) when certain things go....
3. Power/ modifications has to go to carb in my opinion, the world is your oyster in that respect. Spi is definatly more limited but im giving it a shot anyway.
Over all, i love my spi, i love how it runs, how it looks after itself. ECU anyday!
Posted 23 December 2011 - 12:18 PM
Fuel injection is without doubt more reliable as it doesn't have the same issues with cold and damp that a carb model does, but then a well maintained carb model with electronic ignition can be virtually as reliable. It's also worth remembering that aside from the fuel injection system, an SPi is still a classic mini in every other way and therefore is still as prone to all the non fuelling related breakdowns as a carb mini is. My carb mini has broken down a number of times, none of which were related to the carb or fuelling, exactly the same breakdowns could still have occurred with an injection model. A fuel injection model also has more wiring & electrical components than a carb model does and we all know how problematic mini electrics can be!!
As others have said, tuning options are restricted on injection models as the standard ECU can only handle a limited level of modification. There are certainly a lot more tuning options with a carb model, but realistically the majority of mini owners hardly ever progress beyond a stage 1 kit anyway, let alone the uprated cam, modified head and 90 BHP possible from an injection model. So in reality, this is unlikely to actually be an issue for the average mini owner.
So all in all it depends what you want out of a mini and what you are going to use it for. If it's a daily drive that needs to be as reliable as possible with the minimum of maintainance and you don't intend to modify it greatly, then an SPi is probably the most suitable, for hobby cars and petrol heads, where time and reliability is less of an issue, then a carb model is probably the better option.
Edited by AVV IT, 23 December 2011 - 12:25 PM.
Posted 23 December 2011 - 12:28 PM
Posted 23 December 2011 - 12:35 PM
will be watching this closely, I am a complete noob on mechanicals and body work having never even touched a spanner for fixing a car
many thanks
max
Posted 23 December 2011 - 12:39 PM
Posted 23 December 2011 - 12:44 PM
Posted 23 December 2011 - 12:50 PM
1. Reliabilty - injection
2.Maintenence - not much difference
3.Power/Modifcations - carbs
Posted 23 December 2011 - 12:51 PM
Posted 23 December 2011 - 01:07 PM
If standard Spi power is good enough then don't be put of by those who worry their ecu is going to pack up with all those wiggly amps and leave you stranded. Most problems with injection are connections from sensors getting corroded and that's not the system's fault. I have another 'electronic' car (as most are now) and the only fault in 15 years that stopped the injection system from working properly was a faulty brake light switch but it still got home if rather slower than normal.
For sale next summer/autumn, a 7000 miles from new 1275 A+ motor will all the ancillaries including fuel tank........ It will be advertised with a video showing how quick it is, how mechanically quiet it is with oil pressure/temp gauge and compression readings etc etc to distance it from those completely unknown second hand engines from breakers.
Edited by govig, 23 December 2011 - 01:12 PM.
