Injection Or Carb?
#16
Posted 23 December 2011 - 01:10 PM
#17
Posted 23 December 2011 - 01:38 PM
carb engines are also easier to modify but injection would be better if you are going to keep standard.
the engine is also simpler to strip down on a carb model
it all depends on what you plan to do with it, if you are going to modify then it is easier to get a carb model
there isn't much in it really, it is just down to what you want at the end of the day
Rhys
#18
Posted 23 December 2011 - 01:43 PM
2. Maintenence - Debatable
3. Power/Modifcations - Carb
Buy injection if you're keeping it standard, buy carb if you're planning to tune and modify it.
Edited by Mini_Magic, 23 December 2011 - 01:45 PM.
#19
Posted 23 December 2011 - 02:48 PM
One other thing to remember is the car you get with the fuel delivery system, for example the 94 onwards injection mini's come with much comfier seats.
Apart from the fact that the so called "SPi Seats" that you are referring to, were not actually exclusive to the Spi models. They were also fitted to the late HIF 38 carb models ('92 onwards) as well.
also am I right in thinking that the later SPi/MPi models were more prone to tin worm???? or is that just a rumour??
Having seen it for myself I can confirm that it's not just a rumour. It's debatable whether the early 90's carb and SPi models were actually any more prone to corrosion than earlier 80's examples. But thanks to poor rust proofing and a few other production issues, the MPi models certainly were. I've seen a few examples of rotten MPi's in a far worse state of corrosion than untouched Carb & SPi models that are significantly older.
Edited by AVV IT, 23 December 2011 - 02:50 PM.
#20
Posted 23 December 2011 - 03:29 PM
Well if i sell my Ford fiesta the mini i purchase will become my daily drive.
Ive previously owned both SPI and a carb'd Mini.
So it would need to be reliable yet i want a bit of grunt. I dont want some 1380 engine thats been so lightened it can just about tickover
If i knew more information on Carb'd models, i would jump at them straight away as i would have no problem with being able to set up the mixtures etc.
Its abit hard to be honest. My project clubmans gunna be the toy so yeah
#21
Posted 23 December 2011 - 06:20 PM
As major power isn't a consideration, I would strongly consider the SPi models. Even if you want major power, it can be done at a fairly high cost. Having said that, power doesn't come that cheap in carb'ed models either.
The big thing for me that swings it the way of carbs however is the look - a nice simple carb'ed mini has a much less cluttered and neat engine bay than an SPi. I know there are some pretty tidy SPi bays out there, but the carb'ed ones are easier to do.
#22
Posted 23 December 2011 - 09:03 PM
the injection minis are smoother and quieter to drive.
#23
Posted 23 December 2011 - 09:20 PM
#24
Posted 24 December 2011 - 09:09 AM
The final point about power is a tricky one. The standard fit injection systems (mpi and spi) are not readily tunable, unlike a carb where you can change or modify bits to alter the fuelling. this is then the limiting factor of the standard injection systems.
However, such kits as the Specialist Components one offer a fully mappble system, so you can tick all 3 boxes for injection. But as originally said, it aint cheap.
