Help! Water Leakage!
21 replies to this topic
#1 PaddyShepherd
PaddyShepherd
  • 687 posts
  • Local Club: BOGMOG
Posted 31 December 2011 - 03:36 PM
Hey guys.
I'm kinda new to the whole mini game after just purchasing one for my first car. I've purchased a '92 British Open classic, and recently discovered water in both footwells, as well as some minor rot.
I've ripped out the carpets and sound proofing to try and locate the leak. We've checked the door seals and have noticed a minor, small leak. So we dried up the floors, put the carpets back in, and are about to order new door seals. However; after going out in the rain yesterday, we again noticed some water in the footwells. At first we assumed this was purely the door seals. We left the car in the garage over night, and after checking today there is a good inch or so of water in the passenger footwell, and about 1/2 an inch in the drivers, as though it's been filling up in something then leaked in over night. It can't really be the heater matrix, as it only occurs after a rainy drive or clean. Trouble is i will be using this car for work 5 days a week in the new year, and would really like to get it sorted. Any suggestions of other places that it could be getting in?
Thanks in advance,
Paddy.
#2 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 31 December 2011 - 04:00 PM
windscreen?
or being an open classic poss the roof?
#3 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 31 December 2011 - 04:04 PM
windscreen?
Roof seems fine, no signs of leak. There is a drip from the screen every now and then, but nothing that could equate to this amount of water. :/
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 31 December 2011 - 04:08 PM
Try this other thread here that's covering a very similar subject today..... :thumbsup: http://www.theminifo...__fromsearch__1
#5 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 31 December 2011 - 04:18 PM
Thanks for that, only one thing on there that I think it could be though, and even then I'm not sure, any other suggestions?
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 31 December 2011 - 08:05 PM
Have a good look at the windscreen seal and if required pop it out to see if its cracking through age. You can then see if the scuttle is damaged ie rusty.
Have you had a look at your radiator fluid level?? if this is low it could be the pipes to the heater matrix leaking or the matrix itself.
To be honest the best thing to do is strip out the carpet then get somebody to hose the car down while you are in it and go from there.
#7 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 31 December 2011 - 09:26 PM
What condition are the rubber plugs in the floor pans? Could be water coming up, alternatively rust in a wheel arch maybe. The way in may not necessarily be where the water collects.
#8 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 01 January 2012 - 12:33 PM
Don't think it's the arches, they seem fine. Where are these rubber plugs that you speak of? :shy:
#9 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 01 January 2012 - 12:39 PM
If you look at the floor pan you will see round rubber plugs about and inch or so in diameter. There are several in the front and again several in the back although you may find these have been deleted by a previous owner by welding in blanking plates.
#10 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 01 January 2012 - 09:48 PM
- Yeah I can't see them anywhere, but there's no sign of plates being welded over..
#11 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 01 January 2012 - 09:55 PM
Its possible you never had them to start with or somebody has inserted blanks and ground flush. I have done that on Project Erm. The fact you cannot see any bungs or holes rules out water ingress from there.
Have you had a look up around the fresh air vents either side, there may be rust there.
Have a look at the bottom of each flitch. Shine a torch in from the wheel side to see if there are any perforations.
A bit like this
#12 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 02 January 2012 - 12:31 AM
Okay so after ripping out the rear carpets as well tonight, this is much much worse than I had thought. I'll upload pictures at a later date, but man, at the moment it's scarily bad. I'm going back to see the previous owner tomorrow, with two choices; He pays some money back towards repairs, or, he pays it all back and I walk away without a car. I'm so bummed about this, so unhappy that my first car has turned out to be such a rot box, :( I should've known it was too good to be true.
#13 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 02 January 2012 - 12:45 AM
A bit like this
Could you show me a wider picture please? I cannot see where this is supposed to be..
#14 PaddyShepherd
PaddyShepherd
  • 687 posts
Posted 02 January 2012 - 12:55 AM
Oh! Right, I see it now, thanks!
#15 mk1leg
mk1leg
  • 9,343 posts
Posted 02 January 2012 - 02:16 PM
check your water heater matrix , hoses,
