My 1997 Mpi Project - Fin
22 replies to this topic
#1 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 01:10 AM
Right Then,
The old thread was a bit unorganised and sloppy. so ive decided to start over.
Basically I've been involved with minis since I was very little, i was taken to hospital in a stripped out clubman when I was in the womb :)
I have always wanted a mini but I just never had the money or the time. so when the time came for me to get my first car it was inevitably going to be a mini :)
In August 2010 I started looking around mini.
rather foolishly I bought the first car I went to look at (what I thought was a 1997 sportspack) I was (and still am) quite inexperieced with it all but I had a good root around in all the usual problem areas and it looked to be in good condition. so all excited I bought the car, i took it for a service after about one hundred miles and i was a little taken back as it needed:
- Top and Bottom Ball joints each side
- Rear radius arms had a dangerous amount of play
- the manifold was blowing somewhere but they couldnt work out where ?!?
- the exhaust had dropped in the middle aswell.
thank fully I managed to get the money out of the guy who i bought it from to fix it.
here is what the car looked like when I bought it:
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
#2 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 01:13 AM
I drove the car for about 6 Months when a rather scary amount of rust began to show, I ended up getting the passenger side A-panel replaced, a repair to the inner wing and sill and some patching up in the boot.
Another couple of months after that I started poking around the front grille as there were some quite big rust bubbles under the lights, which then turned into this:
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
Im very lucky that the damper mount lasted out otherwise that could have been a bit messy!
Also I may have ended up having an unexpected hello from the rear subframe with the state of the mountings!
Now here comes the bit where some people may accuse me of cheating:
I cant weld, and at the moment dont have the time/space to learn and I got a quote for all of the welding that needed doing and it was going to be around 5500 including the panels. So i had quite a long think and chat with people and I though Sod it .. and I have a new shell from BMH on the way in around february. I had already put too much money into the car to sell it and when this is done I definately dont plan on selling it.
My ideas for the build are:
- keep the tahiti blue and white roof/bonent stripes
- Standard interior with retro touches ( classic steering wheel, also gonna have a 3 gauge dash
- WP arches or mini specials from minisport with 10x6 deep dish mini lights (im thinking polished lip with a gold centre)
- and most importantly - LOW
#3 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 01:14 AM
The old shell has been taken away now, its supposedly going to be turned into a grass tracker/off road racer.
After All this I stripped the subframes and sent them off for blasting:
As you can see the subframes were pretty rusty! .. they have been welded up and ive given them the first coat of Epoxy mastic paint.
when stripping the front subframe I found that the Hi-Low trumpet had dislodged itself from the suspension cone and was cutting its way through! .. good job I found it when I did really:
We couldnt get any top repair plates, so we made a template and got some laser cut, we decided to get them a couple of mm thicker for strength
Once the subframes were blasted we got to painting, after another layer of Epoxy mastic I plan to seal any joins and then give it a light coat of stone chip
#4 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 01:17 AM
Ive now got the majority of suspension and brake parts, just need some bearings and a few nuts and bolts etc.
Rear Adjustable camber brackets
Adjustable tie rods
Adjustable bottom arms
Polly Bushes
Lowered GAZ 36 point dampers
Genuine Hi-lows
2 new cones:
Also have some new rear backplates from minisport :) as mine were buggered!
Now we move onto the engine:
when i drained the engine oil some shards of what looks like brass came out with it:
block painted:
the engine is being rebuilt by a company called autospeed in Bollington (near macclesfield my hometown)
ive bought a few parts for the rebuild:
Oil Pump
Water Pump
Big End Bearings
Main Bearings
Timing Chain and Tensioner
Primary Oil Seal
Engine Gasket Set
Head Gasket Set
Gearbox Gasket Set
Oil Pressure Relief Valve
Thats it so far guys,
any feedback is very much appreciated!
#5 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 08:14 AM
I will be giving the subframes a final coat of epoxy mastic and then get to seam sealing and stone chipping this weekend :) Updates to follow.
#6 newnham500
newnham500
  • 221 posts
Posted 06 January 2012 - 09:04 AM
you took on some serious rust there, god i hate rust. very nice job though, did you find out what the shards of metal where
#7 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 06 January 2012 - 09:11 AM
Bit of a worrying amount of rust >_<
At least it's all getting sorted properly by the looks of things
Good job! :lol:
#8 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 11:08 AM
Thanks a lot! :):)
i was a tad worried by the amount of rust myself!
No I still dont know what the shards of metal are! I was hoping that someone on the forum could shed some light. Im taking the bits that come out of the engine over the to chap whos rebuilding it for him to have a look.
#9 mini_in_progress
mini_in_progress
  • 641 posts
Posted 06 January 2012 - 11:43 AM
i have yet to strip a mini engine but by that amount of metal them sizes id be checking bearings in rods and gearbox first buddy
good luck with your rebuild
#10 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 11:53 AM
Okay thanks! my initial thought were thrust washers? I dont know much about the engines myself though
#11 ZEBERDEE
ZEBERDEE
  • 110 posts
  • Local Club: Box Hill Mini Club
Posted 06 January 2012 - 03:50 PM
Cant believe that there was that amount of rust on your car :ohno:
Looking forward to seeing when you get the new shell and get it all put back together.
#12 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 06 January 2012 - 04:03 PM
I dont understand myself! .. it looked in alright nick! .. and then it just disintegrated!
cheers man, I cant wait to get the new shell :) :D :D
#13 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 06 January 2012 - 08:25 PM
Another interesting Mpi project! The amount of underlying rust looks very daunting! Especially when I finally decide to refurbish my Sportspack!
What plan's do you have for the exterior? This project looks very promising. :-)
#14 chrisj
chrisj
  • 283 posts
Posted 07 January 2012 - 11:23 AM
I can't believe the rust on this, I've been looking at a few sports pack for a show car but this has seriously put me off.
I think uve gone the right way with a new shell, what's the plan for rust protection on the new shell? Well done for saving this though, many would have given up!
Chris
#15 mark-tkm
mark-tkm
  • 168 posts
  • Local Club: DCMOC
Posted 08 January 2012 - 09:42 AM
for the exterior im thinking keeping the tahiti blue as I love the colour, with white roof and potentially bonnet stripes again.
Chrome bullet mirrors,
MK3 rear lights and removing the rear lamp from the boot and smoothing the holes off.
either Wood and picket arches or Mini special arches from mini sport
and 10x6 deep dish minilights .. im looking at gold centre with a polished lip atm.
so all in all im going for a slight modern/retro look :)
