Petrol Tanks Sandblasting
25 replies to this topic
#16 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 06 January 2012 - 10:17 PM
If they're rusty enough to go in holes through sand blasting, they're too rusty to use!
#17 mickeyd515
mickeyd515
  • 260 posts
  • Local Club: none yet
Posted 06 January 2012 - 10:20 PM
it was just a quiery cause i wasnt sure how powerfull the sandblaster is
#18 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 06 January 2012 - 10:29 PM
So long as it's sand or grit, you'll be fine. Make sure you duck tape up the holes and keep the grit away from them. If it's a bead blaster, avoid as that's too harsh for mild steel.
#19 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 January 2012 - 10:31 PM
What about alumina?
#20 mickeyd515
mickeyd515
  • 260 posts
cheers for the tip :proud:
#21 pdaykin
pdaykin
  • 587 posts
Posted 07 January 2012 - 09:34 AM
Personally, I wouldnt blast them - but it all depends upon what kind of blaster you have, how good you are and what standard of finish you want.
Blasting can cause distortion.
Wire wheels are normally fine - there arent that many nooks and crannies which really makes blasting necessary
#22 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 07 January 2012 - 12:14 PM
Plus wire wheels are cheaper unless you have a sand blaster that is?
#23 mickeyd515
mickeyd515
  • 260 posts
Posted 07 January 2012 - 01:53 PM
i dont have a sand blaster my mate does and he said i could use it any time i wanted .ive already done my subframes ect and they look great after blasting
#24 pdaykin
pdaykin
  • 587 posts
Posted 07 January 2012 - 05:31 PM
Subframes are far more substantial than petrol tanks. Unless you are gentle you will distort it
#25 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 07 January 2012 - 05:35 PM
I cant see how a petrol tank is going to distort so easy, it hasnt got vastly long flat surfaces, most of it being curved will hold its shape id guess. We used to media blast some quite presision parts where i used to work and we never had a problem. But of course this is depending on material... heavy shot for doing industrial stuff isnt fit for purpose
#26 mickeyd515
mickeyd515
  • 260 posts
Posted 07 January 2012 - 05:36 PM
thanks everyone for the advice much appreciated :D
