Could A Vauxhall Or Kseries Mini Be Used Everyday?
#16
Posted 15 January 2012 - 12:10 PM
I like the idea of a smaller vauxhall engine, as I don't want a big heavy lump ruining the mini driving experience. I think a sensible and reliable 100bhp would be nice, But then again you can pick up the k series so cheap that there is the temptation of going all out with a vvc k series and about 145bhp on tap.
Which one will comfortably fit under the standard steel round nose, I'm not entirely convinced about the longer front ends but I would consider a fiberglass flip front.
I need to double check insurance costs before anything goes ahead as I will only be 21, anyone had any issues with insurance with engine conversions at around my age?
#17
Posted 15 January 2012 - 12:15 PM
#18
Posted 15 January 2012 - 12:17 PM
The 160bhp vvc I bought, I paid £350 for with wiring, ecu and everything else from a mgzr 160.
Edited by samsfern, 15 January 2012 - 12:20 PM.
#19
Posted 15 January 2012 - 12:24 PM
On the emissions side of things any vauxhall with a letter first in the engine code is designed to run a cat so you can fit one if needed
Edited by Frisco, 15 January 2012 - 12:29 PM.
#20
Posted 15 January 2012 - 12:28 PM
If a 1.4 k series was fitted in a custom subframe, are they the same size as a 1.8 vvc?So if I decided a bit later on to upgrade would it be a fairly simple engine swap? Really it all comes down to insurance and the complexity of the build.
I do love the idea of a 160 bhp vvc mini though
#21
#22
Posted 15 January 2012 - 12:32 PM
They do have head gasket issues, but once they've had the uprated multi layer steel gaskets fitted their fine.
I could say vtecs are crap as I've seen a few of them with holes in the blocks, but I do think their good engines.
Edited by samsfern, 15 January 2012 - 12:33 PM.
#23
Posted 15 January 2012 - 12:36 PM
#24
Posted 15 January 2012 - 12:39 PM
The k series will definitely fit under a standard round nose mini then?
I don't want to start a big debate about which engines are crap etc, as they have a tendency to go over the same old ground. I am aware of head gasket problems etc and I'm sure almost every engine has it's problems.
Having said that I am by no means ruling out the vauxhall option, if a good one of either engine comes up cheap I wil go for it
