Hiff 44 Carb On 998
Posted 16 January 2012 - 01:41 PM
Posted 16 January 2012 - 01:55 PM
Posted 16 January 2012 - 01:58 PM
Posted 16 January 2012 - 02:16 PM
Posted 16 January 2012 - 03:11 PM
Posted 16 January 2012 - 04:48 PM
Posted 17 January 2012 - 01:46 PM
Posted 17 January 2012 - 02:00 PM
oh right basically if you leave it over nite it doesnt want to know wen u start with choke or without but if u bump it it will start and run ok and if u switch off hot and turn bk on it will start.
Have you tired like cleaning the carb at all or adjusting the fuel air mix?
Normally if its not running right its down to being set-up right of very dirty, but just putting on another carb wont necessarily fix the problem as you'll still have to adjust fuel air mixtures to get it running right.
Its just a case of take it apart and check it over for any obvious problems and clean it. alot cheaper than getting a new carb!
Posted 17 January 2012 - 02:01 PM
oh an also try use some punctuation, as its pretty difficult to read a rambling sentence
Posted 17 January 2012 - 02:46 PM
what needle do you useI run hif44 with ITG ram air kit on my 998 and i think its fantastic, have no issues at all with it
Posted 17 January 2012 - 02:49 PM
Is your ignition system set up properly? Check the condition and settings (points gap, plug gaps etc) of the ignition components. If your timing is out or you have a fault with the ignition system this could be the reason for your starting problems.
Edited by surfblue63, 17 January 2012 - 02:51 PM.
Posted 17 January 2012 - 03:17 PM
BDL
Posted 17 January 2012 - 04:40 PM
Posted 17 January 2012 - 05:49 PM
Could YOU maybe use real words instead of "U" and lazy USAmerican spelling of NIGHT...and when instead of wen or back instead of bk.oh right basically if you leave it over nite it doesnt want to know wen u start with choke or without but if u bump it it will start and run ok and if u switch off hot and turn bk on it will start.
( there...got that out of my system )
I was running a 44 on a 1098 with a 12g295 head. I found a 38 worked much better with a AAU. Eventually I switched to twin HS2 which I found even better.
Posted 17 January 2012 - 09:13 PM
I don't do it, but it really doesn't offend me to the point of telling someone off about it.
We all write "carb" and "diff" etc(are you going to tell me off for writing etc now?!), they are all abreviations/short hand, why does it have to be any different with other words?
Anywho...
